Old 05-28-2012, 12:13 PM   #1
cst350
cst350's Avatar
Initial start up
Went to fire my small block up today after a rebuild. The motor sat a while so I put some oil in the spark plug holes and turned it a few rotations. Also pre oiled with a drill through the distributor drive until I had oil coming through the push rods. Motor fired up and ran nicely for a minute or so and then lugged out. I pulled the spark plugs and they had oil on the tips. Think I over did the oil in the cylinders?
I was going to clean the plugs off and try again... any other suggestions?
Thanks,
CST350
cst350 is offline   Reply With Quote
Old 05-28-2012, 12:28 PM   #2
jocko
jocko's Avatar
Re: Initial start up
I'd say you're probably right. Give it a shot after cleaning/drying. Priming the oil pump is probably all that was necessary unless it sat for a LONG time, but no harm done. Better safe than grenaded.
Old 05-28-2012, 12:31 PM   #3
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
If it's a flat tappet camshaft... make sure you have the proper break in oil or break in additive. Also... when it fires... you need to get it up to 2,000 to 2,500 rpm's as soon as possible and leave it there for at least 20 to 30 minutes. This ensures the cam and lifters wear in properly and you wont lose a cam...
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 05-28-2012, 12:50 PM   #4
cst350
cst350's Avatar
Thanks for the quick reply, really want to hear this thing run, especially after that little tease!
I do have the break in additive... Think it would help to turn it over a few times before I put the plugs and dist back in?
Old 05-28-2012, 03:03 PM   #5
Tmwoodall
No. I rebuilt mine twice and learned the hardway, as few turns as possible before you get it to that breakin period. I put myself through a lot of grief. If it were me, clean it, fire it and bring it up to break in RPM right away.
www.tomthetruck.blogspot.com <-- Aka build thread.
Tmwoodall is offline   Reply With Quote
