Old 05-30-2012, 04:20 PM   #1
LowLifeS10
LowLifeS10's Avatar
GMC rear end wider than chevy's?
Hi
I read somewhere that GMC used wider rear ends than chevy did, is that true?
LowLifeS10 is offline   Reply With Quote
Old 05-30-2012, 06:01 PM   #2
Tim Christian
Tim Christian's Avatar
Re: GMC rear end wider than chevy's?
Not 67-72 for sure that I have ever came across.
Tim Christian is offline   Reply With Quote
Old 05-30-2012, 06:59 PM   #3
I don't believe that's true in any year. Gotta wonder why they ever would.
Old 05-30-2012, 08:56 PM   #4
cobrajet21
cobrajet21's Avatar
71 and up rearends were 1 and 3/4 inches wider because of disc brakes on front
http://67-72chevytrucks.com/vboard/s...d.php?t=288820
68 Chevy CST project
02 Chevy Silverado Ex.cab
71 Ford Torino Cobra
cobrajet21 is offline   Reply With Quote
Old 05-30-2012, 09:21 PM   #5
...on Chevy and GMC.
Old 05-31-2012, 05:47 AM   #6
LowLifeS10
LowLifeS10's Avatar
Ok, does anyone know how wide they are? (drums) And between what points do I measure?
Old 05-31-2012, 06:38 AM   #7
lolife99
67-72 parts collector,…
lolife99's Avatar
What year truck rearend are you working with?
5-lug?
6-lug?
Measure between the backing plates.
It will be either 55.5" or 57"
There was an early rearend (55.5") and a late (57") rearend.
Keith
Convert to disc brakes.
Old 05-31-2012, 08:54 AM   #8
duallyjams
duallyjams's Avatar
Del mention that the GMC rear is wider then chevy in the sancho build thread http://67-72chevytrucks.com/vboard/s...d.php?t=516801
James
63 GMC V6 4speed carryall
65 chevy swb bbw V8 auto
68 K20 327/4 speed, buddy buckets
2002 GMC CC Dually Duramax
64 GMC lwb 3/4 V6 4speed SOLD
66 GMC swb bbw buddy buckets SOLD
IG duallyjams
The only thing that stays the same is constant change!
duallyjams is offline   Reply With Quote
Old 05-31-2012, 09:21 AM   #9
LowLifeS10
LowLifeS10's Avatar
yes it was in his thread I read that!
Its a 68 with 6 lugs.
Old 06-04-2012, 03:38 PM   #10
LowLifeS10
LowLifeS10's Avatar
I think its 57" if I measured correctly.
Its 57" when I measure from point number 1. its that the right place to measure from?
If it is 57" and I want to convert it to disc brakes will it get 1.5" wider?
