Old 06-03-2012, 12:38 PM   #1
WETOWM
6 lug to 5 lug swap
I have a 70 12 bolt coil spring posi rearend it has the 6 lug axles can i just change the axles & brake drums from a 5 lug rearend will they interchange ??
WETOWM is offline   Reply With Quote
Old 06-03-2012, 03:59 PM   #2
Jurassic-1
Jurassic-1's Avatar
Re: 6 lug to 5 lug swap
You can get the front 5 lug change over from CPP or McGuaughs. They also have the rear axle kits. You will need to measure the axle length. there were 2 widths. Earlier trucks seem to have the narrow axles which are hard to find used 5 lug axles for.
Jurassic-1 is offline   Reply With Quote
Old 06-03-2012, 07:06 PM   #3
WETOWM
so 69 -72 rearend are differant ?
Old 06-03-2012, 07:08 PM   #4
bubbaj
Mid 70 they started using the wider width rears
1970 c-10 lwb named "heavy metal therapy"
bubbaj is offline   Reply With Quote
