Old 06-03-2012, 07:28 PM   #1
sflem61
how do i fix this problem?
went to install my one piece drive shaft in the 67 swb, ears that hold universal joint in rear yoke are gone, look like they were take off with a grinder by previous owner, by my u-joint hooked up perfect, was wondering if i could spot weld bearing caps in place to yoke
sflem61 is offline   Reply With Quote
Old 06-03-2012, 07:38 PM   #2
El Campo
El Campo's Avatar
Re: how do i fix this problem?
I think that the yoke is cast iron but I could be wrong. Cast iron is hard to weld as you probably know. I would not weld anything that had power going through it that was cast but thats just me.
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles
72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2)
2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end
2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED)
2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one)
Hook em Horns!!!
El Campo is offline   Reply With Quote
Old 06-03-2012, 07:40 PM   #3
SS Tim
SS Tim's Avatar
I'm thinking you know the answer to this. A picture might change what I am saying but it sounds like it is time for a replacement yoke.
SS Tim is offline   Reply With Quote
Old 06-03-2012, 07:44 PM   #4
treveiger
treveiger's Avatar
Interested in seeing it also
1969 Chevy c20(Miss Hackjob)
treveiger is offline   Reply With Quote
Old 06-03-2012, 08:45 PM   #5
sflem61
i think it is cast, well i wont be spot welding, was looking for a simple fix
Old 06-03-2012, 08:57 PM   #6
GMC Canuck
If you can snap a pic and post it, it would help. Are you missing the U-joint straps?
GMC Canuck is offline   Reply With Quote
Old 06-03-2012, 09:07 PM   #7
oilyrag80
oilyrag80's Avatar
i dont like to admit it but i had a truck where the ears wore down so i just centered the u-joint and tacked it in. It seemed to work, it lasted a few years until i swaped out the complete diff. It was a short term fix at best.
oilyrag80 is offline   Reply With Quote
Old 06-03-2012, 09:12 PM   #8
oklalawnboy
oklalawnboy's Avatar
I think you run the risk of welding the needle bearings in place and the u-joint won't live. make sure you have a phone and AAA when you go driving it. IMO
72 Cheyenne super 10
08 3500 HD 4dr dually
12 ford flex (wifes ride)
76 Monte Carlo
83 Chevy short wide Silverado
96 Mazda Miata, 2000 Allegro Bus
oklalawnboy is offline   Reply With Quote
Old 06-03-2012, 09:18 PM   #9
sflem61
oilyrag80, thats what i wanted to do but now i,m concerned that the yoke is cast, or drill a small hole and put a 1/4 screw that the head will catch the bearing, bearing caps meets up even with yoke
