Old 07-16-2012, 11:23 PM   #1
Mr Chevorlet
Rusty Nuts
Mr Chevorlet's Avatar
I have an issue with cab mounts
I guess I have the C20 cab mounts (first pic) I have cab I am sitting on a 4 wheel frame. So do I need regular C10 cab bushings (second pic) I am really confused on what to get now. When I got these this is what the vender said I needed. First pic. Any help would be great. Oh and it is just a 1/2 ton frame. And if they are supposed to the first pic, which ones go to the front of the cab.
(Clever Missouri) Southwest
Larry
Mr Chevrolet
My Build, The Marathon Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=604414
Mr Chevorlet is offline   Reply With Quote
Old 07-16-2012, 11:43 PM   #2
Pro Performance
Pro Performance's Avatar
Re: I have an issue with cab mounts
I am a little confused as to what you are exactly assembling together, in regards to what cab on what frame. It does sound like you need the 1/2T bushings though.
Are you putting a cab on a 1/2T 2wd frame?
Travis
Pro Performance is offline   Reply With Quote
Old 07-16-2012, 11:47 PM   #3
Mr Chevorlet
Rusty Nuts
It is a 1972 4 wheel drive 1/2 ton frame that I am sitting a 1967 cab on it.
Larry
Mr Chevrolet
Old 07-17-2012, 05:44 AM   #4
JimKshortstep4x4
A four wheel drive frame uses the mounts shown in the first set with the taller mounts. The front cab mounts are the on the right side of the picture second set.
Here is a picture of the front mounts installed.
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end
1965 Impala SS 400 sbc, Muncie rock crusher
1966 Impala SS 396 bbc, TH 400
1969 El Camino, 350 sbc, TH 350
1971 Snowplow built on a Blazer frame
1972 GMC Short bed, stepside, TH 400, 427 BBC
Old 07-17-2012, 09:19 AM   #5
Mr Chevorlet
Rusty Nuts
I guess i have my special helmet on, but you said i will need to use the first set of mounts shown with the taller mounts for the four wheel frame but then you said to use the smaller bushings in the second picture for the front of the cab. them are for a 2 wheel drive frame.
So do i use the short mounts in the first picture for the front and the taller ones on the back
Larry
Mr Chevrolet
Old 07-17-2012, 02:46 PM   #6
Tim Christian
Tim Christian's Avatar
You need the first picture set for a 4X4
Tim Christian is offline   Reply With Quote
Old 07-17-2012, 07:12 PM   #7
ScottG
Try this, it really helped me out.
http://67-72chevytrucks.com/vboard/s...&postcount=446
'67 C20 LBW
ScottG is offline   Reply With Quote
Old 07-17-2012, 07:50 PM   #8
Mr Chevorlet
Rusty Nuts
Thanks for the replies i got the cab on but now the cab is riding on the transmission. sorry i opened another thread on this. sorry guys
Larry
Mr Chevrolet
