Old 08-02-2012, 04:34 PM   #1
riz
need help badly... please help.
I'm trying to remove the rear exhaust manifold bolt on the passenger side nearest the firewall and it won't budge. I've rounded it a little bit too but not too bad. I have to lean way over to get at it and then only have about a quarter turn of leverage if I do break it loose... I also can't hardly get anything on it due to the manifold pipe right next to it..... Please help! I want to pull my engine and wanted the manifolds off before I did so.
Thanks in advance,
RIZ
riz is offline   Reply With Quote
Old 08-02-2012, 04:47 PM   #2
HTX86chevy
HTX86chevy's Avatar
Re: need help badly... please help.
HF has a bolt extractor set for stripped bolts. I would use it. I was able to get mine with an extension on the ratchet.
HTX86chevy is offline   Reply With Quote
Old 08-02-2012, 04:50 PM   #3
THE "10" SILVERADO
THE "10" SILVERADO's Avatar
This doesn't really add to the conversation but you can pull the engine without taking off the manifolds. Just unbolted the pipes and pulled mine. Now I can get to the bolts really easily.
Michael
Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9
THE "10" SILVERADO is offline   Reply With Quote
Old 08-02-2012, 04:53 PM   #4
riz
I know, actually I have no exhaust from a few inches past the manifolds but I kinda wanted to pull it out with them off for some reason. I also want to pull the tranny with it......... any difficulties there?
RIZ
Old 08-02-2012, 04:55 PM   #5
riz
I have a Craftsman extractor set for a 3/8 drive but it won't connect to my 3/8 drive Craftsman extension??? The square hole is too big for the end of the extractor ???
RIZ
Old 08-02-2012, 05:35 PM   #6
DetroitIron
DetroitIron's Avatar
X2
_______________________________________________
1985 Chevy Scottsdale K20 350 with 700R4 running 3.42 gearing aka "The Honey Badger"
1993 Silverado C3500 Ext. Cab Dually 6.5 turbo diesel
DetroitIron is offline   Reply With Quote
Old 08-02-2012, 09:42 PM   #7
russgt
russgt's Avatar
Leave it for now, pull the motor and trans together ( 2 wheel right?) and deal with the bolt once the engine is on the floor or engine stand.
70 stepside
76 blazer
86 Silverado
20 Max Trailering 6.2 Crew
71 Nova SS
My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=363634
russgt is offline   Reply With Quote
Old 08-02-2012, 10:15 PM   #8
86c20
86c20's Avatar
unless you could not get the y pipe to spit off the manifoilds the only other thing to do would be drop the inner wheelwell and go at if that is of couse if it is not ac
1986 c20 "the hillbilly" 350 sm465 3.42gears 21mpg at 70mph
1985 k30 "the ice cream truck from hell" no rust az truck
197-8??? c30 "ramp truck" 454
1978 monte carlo 350 350th with 2.73 gears. no rust. sc car
86c20 is offline   Reply With Quote
Old 08-07-2012, 05:36 PM   #9
motornut
78K & 79C Jimmys
motornut's Avatar
may have to drill out the head remove manifold and weld another on it after
the welding heat may loosen it too
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
