08-06-2012, 10:15 PM | #1 |
TBI to TPI...
Basically my main question is, can I keep my TBI .202 heads and just go with the intake on up for the swap? I plan on getting the whole wiring harness and ECU to do it, and it will be 5.7 parts going on a 5.7 engine. I'm still "studying" on this
1991 Mustang GT Vert, T-5 w/ Pro 5.0, Trick Flow upper & lower, BBK cold air intake, 3:73, BAMA chip, etc. 1988 K5 Blazer, [coming soon] TBI 400, SM465/NP208, 12 bolt rear, 3:08's, looks like a 1980. 1998 Jeep Grand Cherokee 4.0 fully loaded daily driver! Where there's a will, there's a rig! |
08-06-2012, 10:56 PM | #2 |
Parts and more parts
Re: TBI to TPI...
I don't see why not.
Frank |
08-06-2012, 11:02 PM | #3 |
Re: TBI to TPI...
Thanks! I hadn't seen anyone saying the heads were different, I just had to make sure the easy way.
08-07-2012, 12:49 AM | #4 |
Re: TBI to TPI...
Just get an 87+up TPI intake, it will bolt up to your TBI heads. 87+up Corvette intakes use the older bolt pattern so avoid those, Just find a Camaro or Firebird one.
08-07-2012, 03:00 PM | #5 |
Re: TBI to TPI...
That's the plan, seeing as there has been an odd influx of '88-'90 Camaros and Firebirds that are TPI on CL. only problem is, they're all complete and running [even a couple engine/trans packages with wiring and ECU] and I don't need a running one. As long as it ran good before it blew a rod through the pan and I can get the wiring, I'll be happy and it'll be cheaper!
