Old 08-16-2012, 12:48 AM   #1
idreama300
Brake lines???
I've done a McGaughy 12" disc brake conversion on the front of my 65. I still have the drums in the rear. I haven't decided on a master/booster/prop valve yet. I'm wanting to run my brake lines before I put the cab back on the frame. What size steel lines do I run? Do you use different sizes for the drums and discs?
Any advice on some nice sleek master/booster/prop valve? Something that is fairly small and clean looking?
idreama300 is offline   Reply With Quote
Old 08-16-2012, 10:33 AM   #2
jimmydean
jimmydean's Avatar
Re: Brake lines???
When I converted my '69, I used the master and prop valve out of a '75 with stock sized lines. I didn't think about running different sizes and everything went together perfect.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 08-16-2012, 10:36 PM   #3
idreama300
Re: Brake lines???
Thanks Jimmydean. Did you use stock sized lines for the 75, the 69, or are they the same?
