Old 08-26-2012, 03:25 PM   #1
Car'n'Guitars
Car'n'Guitars's Avatar
Leaf Spring Help
Okay so if you put 3/4 ton springs under a 1/2 ton but keeping the 1/2 ton axles, how much will it effect payload wise?
1985 Chevrolet K10 Custom Deluxe---SOLD
1997 Ram 2500 5.9 Cummins
1985 Chevrolet Camaro Z28
1987 Chevrolet K10 Silverado
"The Beast" build 1987 Silverado http://67-72chevytrucks.com/vboard/s...=1#post6150257
Car'n'Guitars is offline   Reply With Quote
Old 08-26-2012, 03:42 PM   #2
INSIDIOUS '86
INSIDIOUS '86's Avatar
Re: Leaf Spring Help
Look up big ten trucks.
The issue with this is you can load more but you can overwork the half ton brakes easily if your not carefull. So upgrade to the bigger brakes as well.
Me and my freind did this once, going down hill with 1800#s in the back of scrap steel and we couldn't stop but luckily his suspension was able to get us out of trouble and away from the ditch lol
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 08-26-2012, 03:49 PM   #3
Car'n'Guitars
Can you put the 3/4 ton brakes on a 1/2 ton axle?
Old 08-26-2012, 04:43 PM   #4
MalibuSSwagon
I'd like to put Big Ten or 3/4 ton springs on my 1/2 ton short bed. I will be towing trailers with brakes on them mostly.
Are Big Ten and 3/4 ton springs the same?
MalibuSSwagon is offline   Reply With Quote
Old 08-26-2012, 05:45 PM   #5
THE "10" SILVERADO
THE "10" SILVERADO's Avatar
Do not think so. Big 10 or the F44 option made the truck a 5/8 ton. I have the heavy duty springs in the rear of my 1/2 ton and while they are a lot more beefy than the 1/2 ton springs (mine has 8 leafs, standard trucks I think have 4-5) I'm not sure if they are as good as 3/4 ton springs.
Michael
Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9
THE "10" SILVERADO is offline   Reply With Quote
Old 08-26-2012, 05:54 PM   #6
Axle
Axle's Avatar
Payload is determined by axle as well (ie: bearing capacity).
I have 7+1 springs in my 1/2 ton. (rated at 2900 pounds each). It takes a lot to make the truck squat, but its nice to toss in whatever I want and not have it become a tail dragger.
Alex.
Axle is offline   Reply With Quote
Old 08-26-2012, 06:07 PM   #7
Car'n'Guitars
Alex.
Have you put bigger brakes on the 1/2 ton axles?
Old 08-26-2012, 07:39 PM   #8
MalibuSSwagon
Yes my 1/2ton has 4 leafs per side. I will look around and order up some Big Ten springs.
Old 08-26-2012, 08:33 PM   #9
74 stepside
74 stepside's Avatar
There are light duty 1/2 tons and heavy duty 1/2 tons. There are light duty 3/4 tons and heavy duty 3/4 tons also. Light duty 1/2s have 4 shorter leafs. The hd option is 8 longer leafs which are the same as light duty 3/4 trucks. Even says so in LMC catalog when you look at replacement springs. So the answer to your question is yes. The longer 56" 8 leafs will fit your truck. Both of my c10 shortbeds came stock with the 8 leaf hd springs.
74 stepside is offline   Reply With Quote
Old 08-26-2012, 09:11 PM   #10
frog210
My 74 c10 shortbed
Has 8 leaf springs on each side
So I guess that makes it a hd half ton?
I have 12 bolt axle and 5 studs
frog210 is offline   Reply With Quote
Old 08-26-2012, 09:53 PM   #11
MalibuSSwagon
SO I will have to move my spring hangers? I did look at my frame a bit while doing my brakes this weekend, The holes in the frame are there to move the rear spring hangers.
Thanks.
Old 08-26-2012, 11:17 PM   #12
74 stepside
Originally Posted by frog210 View Post
My 74 c10 shortbed
Correct you have a hd spring optioned 1/2 ton.
Old 08-26-2012, 11:18 PM   #13
74 stepside
Thanks.
Yes you will need to move the rear hangers back into the next set of holes.
Old 08-29-2012, 08:33 PM   #14
Axle
Axle's Avatar
If you don't need more than 2700 pounds per spring, you can stay with a 52" leaf, no need to move hangers unless you want the longer leaf spring and 3500 pound capacity.
randomn spring seller;
http://www.generalspringkc.com/Leaf_...987_s/1823.htm
Alex.
Old 08-30-2012, 02:03 AM   #15
INSIDIOUS '86
To answer your ignored question yes. Find a 3/4 truck or suburban and they will have the wide brake shoes. You will need to pull your axles and pull your backing plates off. But really if you find a 3/4 ton 10 bolt such as off a suburban they are usually geared better for towing or heavier vehicle weight
Old 08-30-2012, 07:41 PM   #16
74 stepside
Ive owned a 1975 3/4 ton truck and a 1989 3/4 ton suburban. From those and every other 3/4 squarebody truck I have ever seen they had a 14 bolt rear end. Never heard of a 3/4 ton 10 bolt. Since 14 bolt rears are 8 lug, they are completely different than 1/2 ton 5 lugs. I seriously doubt the brakes are interchangeable.
Old 08-30-2012, 09:59 PM   #17
INSIDIOUS '86
The suburban had wider brake drums and shoes this is as far as I know. Either way there is more brake and that will def help for heavy loads
Also the 1-1/4 thick rotors and spindles up front will work great as well. Brake fade from heat is your enemy here. Since with a heavy load+slow speeds that means that the heat does not dissipate. My friends rotors turned blue when we overloaded his. We changed his boiling brake fluid his rotors and pads after that.
