Old 09-09-2012, 08:09 AM   #1
USAF65GMC
USAF65GMC's Avatar
Any tricks you guys got for pulling the brake drums
Well I started working on the brakes since I am waiting on a couple of parts for the engine. The master cylinder was empty expect for some sludge and I had no peddle at all. I was planning on doing a complete rework of the system. Got the master cylinder off, but went to the first drum and it was a no go. I have tried beating the crap out of it and backing off the adjuster, but no luck. Do you guys have any tricks that may help me out.
USAF65GMC is offline   Reply With Quote
Old 09-09-2012, 08:41 AM   #2
Boog
laying low
Boog's Avatar
Re: Any tricks you guys got for pulling the brake drums
It's most likely rusted to the hub. I apply some heat around close to the hub and give it some good smacks in between the wheel studs to knock it loose. Maybe some PB blaster before hand to soak where the drum meets the hub.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 09-09-2012, 08:59 AM   #3
too much stuff
Roadtrip!
too much stuff's Avatar
If you are on the front, there is a chance the drum is still rivited to the hub. May have to pull the castle nut and bearings and pull off as an assembly. Pics may help.
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 09-09-2012, 09:03 AM   #4
Daddy Brim
Daddy Brim's Avatar
Look and see if the screws on the front of the drum are still on. They have a tapered head with a slot. I had to use penetrating oil and a impact screw driver to get mine off.
I'm sorry I called you stupid. I thought you knew already.
67 C-20 Custom Camper
68 Nova 396 it does wheelies
2005 Buick Century the one the wife drives
1989 Toyota Tercel to drive when I can't put gas in the first 2.
Daddy Brim is offline   Reply With Quote
Old 09-09-2012, 09:56 AM   #5
50bomb
50bomb's Avatar
Yes I agree with this. I just put a new master cylinder in and wheel cylinder rebuild kit the other day. Could not get the front drums off worth anything. I was irratated. Finally remember I could take the nut and bearings off and it slid off very easily.
Stovebolt-It is painted
50bomb is offline   Reply With Quote
Old 09-09-2012, 11:44 AM   #6
GRX
GRX's Avatar
^^ My thoughts exactly! I have removed many rusty rear drums that way. Often the drum will give a loud "tick" when the parts free themselves under heat. Even had one pop right off the center hub onto my lap.
1969 c-10 Step Side Long Bed. I-6 250cid = = 1969 Pontiac GTO hard top. 400, 4-speed.
GRX is offline   Reply With Quote
Old 09-09-2012, 02:03 PM   #7
Daner
Daner's Avatar
One of my brakes was sticking on a Nash car I have and backing it off didn't help me either.
What I ended up doing was: I put the lug bolts back in and wrapped baling wire around them in a sort of weave. Then I put the 3 jaw puller on the wire and pulled it right off. Quick and easy. Make sure you remove the castle nut and be ready to catch the bearing.
Dane
67 Chevy Fleet 250/4 speed 1/2 ton
68 Chevy 250/4 speed 1/2 ton for parts
49 GMC Grain truck 235 1 1/2 ton
76 Chevy 350/4 speed 1/2 ton
Daner is offline   Reply With Quote
Old 09-09-2012, 02:27 PM   #8
davepl
davepl's Avatar
It always helps to provide some info on what you're working on... but since you didn't, I'll assume it's exactly the same as mine.
There are two big slotted screws that hold each drum on. It's not going anywhere until those are removed.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 09-09-2012, 06:18 PM   #9
USAF65GMC
USAF65GMC's Avatar
Sorry not to be more descriptive, but thanks for the ideas. It is the front drum on a 69 Chevy C-10. I have not had a chance to try any off the suggestions yet. I have attached a pic.
1969 Chevrolet C-10 SWB 307
Old 09-09-2012, 07:27 PM   #10
davepl
davepl's Avatar
I don't see any evidence of the retaining screws I was speaking of, so they may only be on 3/4T and larger drums.
Do they move around at all? If you can rock them around a little bit but they won't come off, likely the pads. If they're solid, probably seized with rust somewhere. Soak the area around the center hub with PB or liquid wrench, heat, hammer, the standard stuff. I've never seen a puller big enough to pull a drum, but I'm sure they exist.
Someone above mentioned that the drums could be riveted to the hub... I'm not even sure what that means (never heard of drums being somehow riveted to the hub, but then I hadn't seen the retaining screws until they got in my way either), so check that too if you know what he was referring to.
And while I'm throwing out the obvious... are you sure you rotated the adjuster the right way? I can never figure it out from side to side so I generally tighten it until I get drag when rotating the drum and then go all the way the -other- way.
Old 09-09-2012, 08:11 PM   #11
OutlawRider
I just beat the crap out of mine with a pry bar and BFH. Mine were frozen solid though.
OutlawRider is offline   Reply With Quote
Old 09-09-2012, 08:27 PM   #12
JDL
JDL's Avatar
At the 1:00 position is the rivet holding the drum to the hub just pull the cap and take the nut off and the hole thing comes off.
72 Chevy short step side with 454 air and tilt.
72 nova project car
63 chevy II drag car
Agency Iowa
JDL is offline   Reply With Quote
Old 09-09-2012, 09:29 PM   #13
too much stuff
Roadtrip!
You can see the 3 rivits holding the drum on the hub. Pull the nut and bearings and pull the whole assembly. That is the only way you will get it. Once apart you can grind or chisel the rivits off and it will come apart easy next time.
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
Old 09-09-2012, 10:18 PM   #14
pritch
pritch's Avatar
It always amazes/impresses me that after 40+ years, the original drums are still on some of these. I never got a good answer on this, but can the drums be turned with the hub still riveted on?
'68 Panel
Project Boogie Chillin'
'68 C-10
Ol' Green
pritch is offline   Reply With Quote
Old 09-10-2012, 12:28 AM   #15
GuyO
GuyO's Avatar
I had a truck once where only one front drum was rivited! I beat on that thing for about a hour before I realized it was not coming off without pulling off the dust cover and removing the castle nut. Whoever the PO owner was - it was a mean trick! BTW, except for that one hub, it was always the rears it seems that were harder to remove.
GuyO is offline   Reply With Quote
Old 09-10-2012, 03:13 AM   #16
oldspowered67C10
Yes, assuming the shop has the bearing type centering cones for their brake lathe, most shops do.
oldspowered67C10 is offline   Reply With Quote
Old 09-10-2012, 09:54 AM   #17
USAF65GMC
USAF65GMC's Avatar
Thanks for all the ideas! If I have time, I will give it a shot this evening. I have been trying to get the truck running, but had some time while I was waiting for parts, so I started on the brakes. The fun I am having with the ignition might be a whole other thread!
Old 09-11-2012, 09:56 AM   #18
USAF65GMC
USAF65GMC's Avatar
If you are on the front, there is a chance the drum is still riveted to the hub. May have to pull the castle nut and bearings and pull off as an assembly. Pics may help.
That was it! I got them off. Now to replace the wheel cylinders. Thanks for the help!
Old 09-12-2012, 06:10 PM   #19
GRX
GRX's Avatar
The truck in my sig still had the factory shoes and drums on the back. Needless to say they were shot. And yes, turning the front drum while still on the hub is proper way to do it.
