10-02-2012, 08:57 PM | #1 |
81-87 to 88-91 headlight harness
Saw on here a couple weeks ago somebody made an adapter.Don't want to cut my harness if i dont have to and i can't find the thread now.
10-03-2012, 11:23 AM | #2 |
Happy to be here
Re: 81-87 to 88-91 headlight harness
Anyone?
10-03-2012, 01:11 PM | #3 |
BAD BOW-Silverado XST
I've never seen an adaptor. I spliced mine in. It's cool. I can't remember how I wired them up. With the headlights off, the front dual lights flash together and opposite the fender light. With the headlights on, the front dual lights alternate flash, one (inside I think) flashes with the fender.
10-03-2012, 03:15 PM | #4 |
Slots go on anything!
The one I converted I spliced the harnesses together as well. The colors are all the same (at least if you have the dual headlamp setup already). The only difference I had is there wasn't a brake pressure switch wire on the '91 front end I used, since '91 had rear ABS. Seems like it was a tan/white wire with a black single spade plug; it goes to a plug down near the power steering box.
1974 Jimmy- 5.3/4L80e/NP241 |
10-03-2012, 03:54 PM | #5 |
Can't you just pull the pins and place in a new harness?
Posted via Mobile Device |
10-03-2012, 04:08 PM | #6 |
Got me. It was just easier for me to measure down the harness the same distance, and splice it. The connectors for the later style headlights are different.
10-03-2012, 06:22 PM | #7 |
If the pins in both connecters are the same I would pin it. Cleaner look and cut down on weakpoints
