10-18-2012, 03:28 PM | #1 |
Replacing rear wood floor with pickup bed floor?
Has anybody every replaced the wood floor in a 67-72 burb with the floor from a pickup bed? My wood floor in my 70 burb is toast & I would much rather have metal back there. I found a 69 pickup bed floor that is in great condition & thought this might be a stronger option. @ $100.00 it's also cheaper than I can buy the metal for.
10-18-2012, 07:50 PM | #2 |
Re: Replacing rear wood floor with pickup bed floor?
Not exactly what you requested, but here was a discussion on bed floors in suburbans/panels. http://67-72chevytrucks.com/vboard/s...d.php?t=443507
10-18-2012, 08:38 PM | #3 | |
10-19-2012, 08:24 AM | #4 |
Oops ! My bad. I guess I read this to fast . There have been discussions similiar to this- replacing wood with metal floors - but in doing a search I was not able to find them.
I do believe there would be a gap, though. Maybe someone else will come up with more info. Sorry. |
10-19-2012, 11:23 AM | #5 | |
Anybody with ideas? |
10-19-2012, 03:41 PM | #6 |
What?
Personally, I'd stay with the wood floor of the Suburban.
If yours is trashed, then I'd plan to replace it with a good sheet of high quality ply wood. Doing so is a challenge, but it is possible. The key is getting all of the carriage bolts out, and then removing the spare tire tub. Once you do that then the piece in front of the passenger side fender needs to be pulled away, it is tongue/grooved into the main piece of plywood floor. From there you are to "slide" the floor towards the passenger side until it clears the body, then lift up the floor from the rear section and then remove it from the area. All sounds straight forward eh? I ended up cutting mine out, then putting the new piece in reverse order of how it is "supposed" be removed. Lots of sealant, road grime, and rust will be holding the old wood floor into place.
Chris 1968 K20 Suburban 1972 K10 LWB PU |
10-19-2012, 04:23 PM | #7 | |
The how is not a problem. I own a body shop & this isnt anything too difficult. What I really wanted to know is if anybody has done a metal floor before. I couldnt find anything online of one that had been done before. Wood would definately be the easier option & I still may go with it, but I was hoping to find somebody that might have done one before. Thank you for your procedural break down & opinion though. It is definately appreciated!!!!! |
10-19-2012, 06:09 PM | #8 |
Here was a discussion on METAL floor replacement.
http://67-72chevytrucks.com/vboard/s...d.php?t=503606 The edges is /are the gaps I was talking about. Several of the lowered suburbans put a metal subframe with sheet metal in place.Here is a picture of four wheel drive one gone convertable with a recessed metal floor. |
10-19-2012, 07:33 PM | #9 | |
That yellow truck looks like it is ready to go on safari!!! Here is an option. Can you imagine keeping this clean? |
10-19-2012, 07:42 PM | #10 |
Here it is finished and no I would'nt want to keep that other one clean.
10-19-2012, 07:57 PM | #11 |
11-23-2012, 09:53 PM | #12 |
I am alittle late to the conversation but when the lion approach the vehicle you are supposed to say LIKE A GOOD NEIGHBOR STATE FARM IS THERE!
Posted via Mobile Device |
