Old 10-27-2012, 03:27 PM   #1
77ChevySharkBite
77ChevySharkBite's Avatar
Headers and Spark plugs
hey guys I just put headers on my truck and also replaced 4 spark plugs on the block and when I crank it up all its doing is making popping noises anybody got any suggestions?
Korwin
77 C10 Silverado Sharkbite LWB Build
67 Chevy C10 Frame Off
06 Dodge Magnum 2.7v6 aka swag wag!
2010 Honda Accord 2.4I4 DD aka Liquid Metal
77ChevySharkBite is offline   Reply With Quote
Old 10-27-2012, 03:57 PM   #2
75chev4x4
75chev4x4's Avatar
Re: Headers and Spark plugs
I would recheck your wires make sure they are on the correct plugs, maybe got mixed up after swapping plugs.
75chev4x4 is offline   Reply With Quote
Old 10-27-2012, 04:27 PM   #3
77ChevySharkBite
Thank you and yeah that's what I even asked a few people cause yesterday it was fine but today it's making that popping noise
Korwin
Old 10-27-2012, 05:52 PM   #4
77ChevySharkBite
well I switched around the wires, and now the truck wont start but the backfiring sound is gone any suggestions?
Korwin
Old 10-27-2012, 07:25 PM   #5
HTX86chevy
HTX86chevy's Avatar
What was it doing before you swapped the spark plugs and why did you only swap 4 of them?
HTX86chevy is offline   Reply With Quote
Old 10-27-2012, 07:36 PM   #6
77ChevySharkBite
It was running fine but in the process of taking the old manifolds off I broke 4 spark plugs
Korwin
Old 10-27-2012, 08:53 PM   #7
75chev4x4
75chev4x4's Avatar
Did you bump or pull off your ignition wire going to the distributor? Was it starting when you had the backfiring problem?
Old 10-27-2012, 08:56 PM   #8
77ChevySharkBite
No everything was fine and yeah it was starting when it was doing the backfire, when I first started the truck I heard a big pop and ran for about 5-10 seconds then died and then started it again and it kept running with a popping noise which I'd assume is it backfiring
Korwin
Old 10-27-2012, 09:06 PM   #9
INSIDIOUS '86
INSIDIOUS '86's Avatar
18436572 firing order. Driver side is 1357 passenger is 2468
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac
3''spintech prostreet mufflers xpipe 1 3/4 headers
build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217
Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511
INSIDIOUS '86 is offline   Reply With Quote
Old 10-27-2012, 09:13 PM   #10
cmyc5575
may I add from the front of the truck going towards the dist.
cmyc5575 is offline   Reply With Quote
Old 10-27-2012, 09:16 PM   #11
77ChevySharkBite
I checked and fixed the one that I mixed up, I had friend tell me that there could be a connectivity issue that it might not be getting full spark could that be the reason why it's not turning over?
Korwin
Old 10-27-2012, 11:26 PM   #12
75chev4x4
75chev4x4's Avatar
So the motor just cranks but will not start? Can you smell gas getting up to the carb?
Old 10-27-2012, 11:49 PM   #13
77ChevySharkBite
Yes to both questions my friend was saying that it could possibly be my battery because it all the sudden got cold here it might not have enough amps to crank it fully.
Korwin
Old 10-28-2012, 12:04 AM   #14
frog210
I know it got real cold here in San Antonio
San Antonio, TEXAS
-Frog
-I'm a valet and well I've driven BMWs, Mercedes, Porsche,Bentlys, fiats, Hondas, etc and well even do I like a few features, I love my shortbed, it dosent bore me out, just press on the gas and you'll remember why you love it.
frog210 is offline   Reply With Quote
Old 10-28-2012, 12:08 AM   #15
77ChevySharkBite
Yeah it's about 55 here so I really don't think that it getting not enough cold amps to start it would be pretty possible. Cause it was literally overnight that it got cold and I just had to buy a new battery in my car and I had the same thing happen, it was warm and started the day before and the next day it was cold and my car didn't start.
Korwin
Old 10-28-2012, 07:54 AM   #16
75chev4x4
75chev4x4's Avatar
Throw your battery on the charger and see if it cranks up.
Old 10-28-2012, 11:33 AM   #17
HTX86chevy
HTX86chevy's Avatar
Mine recently broke down about a month ago.... It would turn over but never started up. Ended up being the coil. You can have the module tested at the autoparts store and the coil was only about $25 , so its worth a shot.
Old 10-28-2012, 01:11 PM   #18
77ChevySharkBite
Okay I'll keep that in mind another friend had made the statement that if everything is fine on the truck that there would have to be some sort of resistance to prevent it from starting. And I would test the battery but I don't have a volt checker and I'm not longer at my dads house I'm at my place.
Korwin
Old 10-28-2012, 01:47 PM   #19
75chev4x4
75chev4x4's Avatar
Got jumper wires? Jump it off your other vehicle
Old 10-28-2012, 01:49 PM   #20
77ChevySharkBite
Yeah sadly enough I don't have any, but a friend of mine that has the same motor as my truck is coming over so I'm going to have him bring his over and try that.
Korwin
Old 10-28-2012, 02:15 PM   #21
77ChevySharkBite
http://s1048.beta.photobucket.com/us...a3bdf.mp4.html
http://s1048.beta.photobucket.com/us...a8fc8.mp4.html
The first link is the truck running with 1 header on it, and that was Thursday, the 2nd video is what it is doing today. Any ideas?
Korwin
Old 10-28-2012, 11:48 PM   #22
JRANGER
JRANGER's Avatar
hmm thats crazy good luck wish i knew more and could help ya
JRANGER is offline   Reply With Quote
Old 10-28-2012, 11:53 PM   #23
77ChevySharkBite
Yeah trust me I wish I knew it myself but I do thankfully I have a friend that's built a car from the ground up and another that's been a mechanic for about 5 years so trying to get them both to look at it to get it fixed in the first try or process of elimination
Korwin
Old 10-29-2012, 12:41 AM   #24
THE "10" SILVERADO
THE "10" SILVERADO's Avatar
The second video kinda sounds like your starter isn't disengaging right. Hence the "whoooom"ish sound. At least that's what mine did, and why.
Michael
Re-starting the neglected '77...http://67-72chevytrucks.com/vboard/s...=425464&page=9
THE "10" SILVERADO is offline   Reply With Quote
Old 10-29-2012, 08:12 AM   #25
77ChevySharkBite
yeah well none the less the truck is getting a fine park and no start until I can get back on that side of town on tuesday and have a friend come help look at it, but I'm definitely going to be looking into all the options that everyone has suggested to me.
Korwin
