Old 11-10-2012, 01:02 PM   #1
lts70
1970 Daily Driver
lts70's Avatar
Need New HEI Distributor thinking Skip White
I am having distributor problem again with my junk yard GM distributor. I want to buy one of those skip white complete distributors. I have a warmed up 327 with a nv3500 behind it. What distributer model should I get?
It's not truly yours if you didn't build it yourself or if you don't do your own maintenance.
lts70 is offline   Reply With Quote
Old 11-10-2012, 01:27 PM   #2
cdowns
cdowns's Avatar
Re: Need New HEI Distributor thinking Skip White
lots of fans of the cheap skippy chineesey stuff// i prefer higher quality american stuff myself
Old 11-10-2012, 01:54 PM   #3
VetteVet
Msgt USAF Ret
VetteVet's Avatar
What problems are you having? Here is a breakdown and repair of the HEI distributor. With lots of good info.
...........http://www.rustpuppy.org/ignition2/Ignition%202b.htm
VetteVet
metallic green 67 stepside
74 corvette convertible
1965 Harley sportster
1995 Harley wide glide
Growing old is hell, but it beats the alternative.
VetteVet is offline   Reply With Quote
Old 11-10-2012, 05:34 PM   #4
lts70
1970 Daily Driver
lts70's Avatar
My truck randomly cuts out completely. If I let it sit for awhile it will start back up. Sometimes it starts back up and runs fine for awhile and sometimes it dies right away and needs to sit for awhile again. At first I thought it was fuel delivery so I changed my filters and fuel pump and cleaned my carb. Still didn't help.
I noticed that if I kept on pumping the throttle after it cut out that once it fired back up it would backfire loud from igniting the raw fuel that had been running through the system. So I am pretty sure it is loosing spark. I went and bought an excel cap and rotor from NAPA but when I went to put it on this morning I saw that it was a tan color cap (not a big fan of how it would look with my all black, red, and chrome under hood color scheme) So I figured why not just return the parts and get my money back and then swap out the entire distributor for not much more money.
What do you guys think?
Old 11-10-2012, 07:32 PM   #5
Shyguy
Junior Member
Shyguy's Avatar
Sounds like the ignition module is bad, many auto parts stores can check it if you take it in. Many of us carry an extra one in the glove compartment.
'67 Chevy C-20 short stepper - build complete, 454/SM-465.
'75 C-30 Single Cab DRW-350 small block/NP-435.
'77 GMC-6500 Dump Truck, 427 Tall Deck.
'92 GMC K-3500 Duallie, 454/4L80E.
Shyguy is offline   Reply With Quote
Old 11-11-2012, 11:47 AM   #6
Daves70
Daves70's Avatar
Like Shyguy said It's likely your module. Also make sure you are not using your original resisted feed for the distributor. An HEI needs a solid 12volt feed to work properly.
Daves70 is offline   Reply With Quote
Old 11-11-2012, 01:36 PM   #7
Shyguy
Junior Member
Shyguy's Avatar
Good point.
Old 11-11-2012, 01:51 PM   #8
lts70
1970 Daily Driver
lts70's Avatar
So I checked. Even with my discount (work at NAPA on the weekends) An new Ignition module will cost me $26.16 (Echlin Part # TP47). and the cap and rotor kit $22.65 (Balkamp 735-5276)
I just wonder if I should get this for basically the same price and have an all new unit.
http://www.skipwhiteperformance.com/...px?Item=6500-R
Old 11-11-2012, 02:12 PM   #9
Boog
laying low
Boog's Avatar
You used to be able to buy a GM HEI unit from the parts stores for around $100. That may have been a reman'd unit, I don't remember. I bought one of these 6500 Skip Whites last year for my 69 but haven't installed it yet. I thought for that price it was worth trying it. Looks cool too.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 11-11-2012, 02:50 PM   #10
leddzepp
Moderator
leddzepp's Avatar
I have used several Skip White dizzies. Yes they are cheap, but I have never had an issue with one. Drop in and go. You can't beat the price.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 11-11-2012, 03:06 PM   #11
lts70
1970 Daily Driver
lts70's Avatar
Thanks Leddzep I am going to go that route.
Is the one I have posted above the one I want?
Anyone have a promo code to save some cash from there website?
Old 11-11-2012, 03:11 PM   #12
leddzepp
Moderator
leddzepp's Avatar
I bought mine a long time ago off of ebay. The cap does not look like that, so I do not know.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 11-12-2012, 03:19 PM   #13
lts70
1970 Daily Driver
lts70's Avatar
Ordered it this morning. I will let everyone know how it goes.
Old 11-12-2012, 06:07 PM   #14
mr48chev
mr48chev's Avatar
I've had mine from Skip White in the truck for a couple of years and think it needs a tune up now but it has been reliable on my daily.
If you are replacing modules use the good Napa or a genuine Delco as the low buck ones don't seem to hold up that well.
On the acting up part of the ignition, check the wires on the pickup coil. I've seen them break where they connect to the pickup coil and only be held on by the plastic cover of the wire. They would make contact at times for the engine to fire and then loose contact when the advance plate moved.
Also the HEI needs a real HEI wire connector to connect the wire from the ignition switch to the distributor. While a regular female slide wire end will work they tend to loosen up after a while and loose contact while driving down the road. I fought that one when I installed the HEI in my 71 GMC. Drive down the road and have the truck cut out or quit and then get out and fiddle with the wire and connector and get in and go again until it acted up again.
Old 11-13-2012, 12:39 PM   #15
mr48chev
mr48chev's Avatar
I drove my truck to town after posting the post above and the module died when I restarted the truck after stopping at the local mini mart. I don't blame the module it's self but i should be replacing the whole secondary side of the ignition from rotor out real soon as the cap and rotor show that they need replacing and the wires and plugs are due.
The pins that hold the advance weights looked good and that has been a concern on aftermarket distributors. The good thing is that all the parts are a direct interchange with factory parts so after I figured out what was wrong I got it running fairly quickly.
Old 11-13-2012, 01:30 PM   #16
BBGMC
BBGMC's Avatar
I had the Same Exact Problem On my 70' GMC Your Pick Up Coil in the distributor has a small crack in it, when it heats up the crack spreads after cooling down it returns to its normal size and closes the gap enough for your truck to start, took me 4 months to figure that out on mine. I have a MSD Street Fire in my 1968 and it works like a champ.
BBGMC is offline   Reply With Quote
Old 11-13-2012, 03:36 PM   #17
kwmech
www.performancedistributors.com
Old 11-13-2012, 05:26 PM   #18
dropanddrag71
dropanddrag71's Avatar
I had alot of problems with cheap distributors from unknown places. I went to summit and bought an MSD streetfire HEI, cost about 132 bucks complete. I know MSD is good and i also know Summit will stand behind everything they sell. You save the receipt or write the part number down and down the road you can order replacement parts.. cant do that with bargin, unknown internet specials. (Most sell 2nds and blems anyway)
Installed it about 3 weels ago, now starts and runs mint!!
" You are only coming threw in waves,... Your lips move, but i can't hear what your saying"
dropanddrag71 is offline   Reply With Quote
Old 11-14-2012, 01:35 AM   #19
BBGMC
BBGMC's Avatar
I second this I Just Bought an MSD Street Fire also last week and She Purrs real Nice also I also Bought the 8MM Street Fire Wires to match
Old 11-19-2012, 12:24 AM   #20
lts70
1970 Daily Driver
lts70's Avatar
Got the new Skip White HEI installed. Works and looks great.
