11-11-2012, 02:15 PM | #1 |
resident wrencher
So I got a rod knock!
Put a new base gasket on the ole 400 got her warm and drive to town and hear a noise. Get home rev her up and I put my hand on the intake manifold. Harsh knocking inning from within. What do I do?
Posted via Mobile Device |
11-11-2012, 02:50 PM | #2 |
BAD BOW-Silverado XST
Re: So I got a rod knock!
Not good. A rod knock is a ticking bomb. Prepare to replace or repair it.
You can easily pull the crank and have it turned for new bearings. I had a 283 in a '77 that spun a bearing. After fixing it, I sold the truck. Last reported, it ran for several years before the truck was not seen again. I replaced the bearings on a picnic table! |
11-11-2012, 02:52 PM | #3 |
resident wrencher
I think I over sped it I replaced the gasket reved it up it was blowin black smoke from all the unburnt crap in the system that's built up. The I drive it and its there only under heavy load or high rpms in park
11-11-2012, 03:02 PM | #4 |
Base gasket? For the carb? If you have a rod knock for sure then your engine needs a teardown and rebuild
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
11-11-2012, 04:00 PM | #5 |
resident wrencher
It's comming from te block after I reved it up I'm so pissed at y self right. Ow
11-11-2012, 06:13 PM | #6 |
resident wrencher
Started it up it knocks on start up and light throttle now
11-11-2012, 06:52 PM | #7 |
laying low
You should park it and start the teardown before you window the block.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
11-11-2012, 07:03 PM | #8 |
resident wrencher
It's parked I havent even transferred the title so I guess I should rebuild the whole thing and tips or tricks to add in during the build ? I want a stout engine but I need to pass smog for the time being
11-19-2012, 04:37 PM | #9 |
resident wrencher
ok so i took of the left valve cover and all th epush rods look ok i cranked it over to seeif the noise was still audable it actually ran pretty well on the right bank only id idled for about 3 mins the knock was gone but had a faint tick from the right bank it would rev up a bit and it wasnt knocking so my question is if the knock goes away with out spark what is it ? is that a bering piston slap i was idling at about 550 rpm it was knocking at that rpm faintly when the cover was back on and all the plug wires were on
11-19-2012, 04:43 PM | #10 |
resident wrencher
should i drop the pan and see what bering is messed up and see how far the rod and journal are out of spec ?
11-19-2012, 05:08 PM | #11 |
either way the engine will need to be pulled so why not just pull it and inspect on a stand??
11-19-2012, 05:11 PM | #12 |
Piston s knock goes away after a minute so I would say be safe and drop the pan. Prob better to pull the engine since if it is bad you will Prob have to pull it anyways
11-19-2012, 05:16 PM | #13 |
resident wrencher
See I'm not in a postion to pull it I have no concrete or a garage I'm doing all this in the mud of my house I can drop the pan with it in the truck I think seeig as its a 4x4
11-19-2012, 05:22 PM | #14 |
Well go ahead and do that. But if it comes to the point a rod bearing is spun causing a knock the crank will have to come out
11-19-2012, 05:31 PM | #15 |
^^^ Ditto as long as the bearing hasn't spun
Pull the pan and see which rod is bad, I did this on a 350 in a 89 K2500, slapped a new bearing in it and beat the snot out of it plowing snow.
1999 Chevy K2500 RCLB 350 4L80e 2004 Chevy 3500 C&C Dmax Allison |
11-19-2012, 05:46 PM | #16 |
resident wrencher
Idk how bad it is yet ill tear it apart tonight and post some pics
11-19-2012, 05:59 PM | #17 |
Its a bad idea to keep driving with any type of knocking. I'd highly recommend checking it out ASAP.
This is the result of a rod knock that "I'd get to someday" Marked the crank up pretty bad, busted the cam and destroyed the block when the other part of the rod flung around. And it was a long ass walk home lol 13 miles..
1981 K10 Scottsdale
305 ci | TH350 | NP208 | 60k miles |
11-19-2012, 06:42 PM | #18 |
resident wrencher
Ok got te pan down and I found what appears to be rocks? Or chucks of black hard stuff it's not metal none of the rods show obvious signs of issues every thing looks normal cyl walls look ok pistons look ok from the bottom
11-19-2012, 06:48 PM | #19 |
resident wrencher
Mine looks 100% normal no obvious signs of damage on the bottom end
11-19-2012, 07:51 PM | #20 |
Could be excess black rtv from motor assembly.
If the rod bearings look, maybe it's a carbon knock or wrist pin.
11-19-2012, 07:52 PM | #21 |
Is it auto or std trans?
Could be a broken flex plate which will sound just like a rod knock.
11-19-2012, 08:46 PM | #22 |
resident wrencher
It's an auto ill look when I have more free time
