Old 11-15-2012, 08:11 AM   #1
dwatts1984
Oil dipstick Drivers side...
I have a 1985 GMC 1500
Far as I know is has a 5.7L 350 4 bolt main engine.
Recently swapped the 7004r for a turbo 350
Anyhow I bought this truck as a clunker. Paid $400 for it (running). As most of you know people have a tendency to swap the engines in and out of these trucks pretty regularly...
My question is, Ive been looking for an oil pan (gaskets leaking and need to do rear main, might as well replace the crummy steel pan with a nice new aluminum one) through Jegs, summit, and ebay. The problem I'm finding is that based on my year many model, and engine, its showing the oil dipstick on the "passenger" side, however mine is on the drivers side. Is this right? Do you think my engine was swapped previously? If so what years made the driver side dipstick?
Any information or knowledge would be appreciated. You guys haven't steered me wrong yet
dwatts1984 is offline   Reply With Quote
Old 11-15-2012, 08:21 AM   #2
88Jimmy4x4
88Jimmy4x4's Avatar
Re: Oil dipstick Drivers side...
my 1976 has dipstick on pass side so look for that year, this also means a 2 piece rear main seal IIRC
2008 Silverado Z71 RCSB
1991 GMC Jimmy 4x4
1976 GMC Sierra C15 SWB
88Jimmy4x4 is offline   Reply With Quote
Old 11-15-2012, 08:23 AM   #3
TexasJeff
Don't Crush em Restore em
TexasJeff's Avatar
From what I have read on the internet the drivers side dipstick is a 1979 or older casting. 1980 is when the dipstick changed to the passenger side.
TexasJeff
2009 Silver with Linen Interior Cadillac DTS
1990 Red with White Top and Interior Ford Mustang GT convertible
1998 Red with Gray Interior, C3500 Chevy Crew Cab Dually
TexasJeff is offline   Reply With Quote
Old 11-15-2012, 08:37 AM   #4
dwatts1984
See thats what Ive been seeing. Based on the oil pans, it appears the 85 and up are passenger side... however Ive also seen 80-85 passenger side... then 79 and earlier drivers side...
Guess I'm just confused is all. Hate to order something thats not going to fit... then return it wait more time to get the correct one.
Old 11-15-2012, 08:39 AM   #5
piecesparts
Parts and more parts
piecesparts's Avatar
The year of the engine is the deciding factor for the dipstick. Many of the replacement engines that GM sold had an option for both sides for the dipstick. You just put the supplied plug in the hole that you did not use.
Frank
piecesparts is offline   Reply With Quote
Old 11-15-2012, 09:12 AM   #6
dwatts1984
Where might I be able to find the "engine code" to verify the engines year. Thats kinda the dilemma now, is that Im pretty sure the motor was swapped... But i Know nothing about the engine thats here.
Old 11-15-2012, 11:54 AM   #7
rfmaster
rfmaster's Avatar
Sometime in its past original engine was swapped to a replacement mill with pre 1980 block. Starting 1980 dipstick tube was moved to passenger side. To confirm this look at block casting number and block cast date on the bell hosing flange area. With the engine in the truck it maybe very difficult (accessibility and covered in oily crud). Another area to look at is passenger side block deck surface - RPO designation, if still there, can shed a light.
//RF
"The Beast"
1975 Chevrolet C20 longbed
350/700R4! with 3inch body lift
Dual Flowmasters Super 40's!
TBI retrofit completed (2007-07-29)
New 383CID (+030) 08-304-8 9.5:1CR x36,005 (2012-12-17)
rfmaster is offline   Reply With Quote
Old 11-15-2012, 03:45 PM   #8
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Usually truck blocks had them on the passenger side and car blocks had them on the driver side.
Tony
1985 GMC K2500 restoration Project: Rust, White & Blue
1989 Chevy R3500 CC Cummins & 4X4 swap some day...
1989 Burb (D60, 14BFF, 12V, NV4500, NP205, 37" tires in progress)
1985-GMC is offline   Reply With Quote
Old 11-15-2012, 07:55 PM   #9
88Jimmy4x4
88Jimmy4x4's Avatar
huh?
1991 GMC Jimmy 4x4
Old 11-15-2012, 08:14 PM   #10
1985-GMC
Chevy Enthusiast
1985-GMC's Avatar
Dipsticks dipstick
Tony
Old 11-15-2012, 09:03 PM   #11
C-10 simplex
Is your concern is that the left side dipstick will interfere with the exhaust manifold?
C-10 simplex is offline   Reply With Quote
Old 11-15-2012, 10:28 PM   #12
dealrcn
dealrcn's Avatar
Frank is right. Your engine is more than likely a Gm crate engine swap. They had provisions for the dipstick to be on either side.
dealrcn is offline   Reply With Quote
Old 11-15-2012, 10:36 PM   #13
88Jimmy4x4
88Jimmy4x4's Avatar
Originally Posted by 1985-gmc View Post
dipsticks dipstick
lmfao
1991 GMC Jimmy 4x4
Old 11-15-2012, 10:39 PM   #14
GM-power
GM-power's Avatar
I agree that gm crates offered dipstick provisions on both sides. Remember to " think with your dipstick jimmy"
1979 Sierra Classic Heavy-half
1996 Silverado x-cab "the daily"
GM-power is offline   Reply With Quote
Old 11-21-2012, 08:40 PM   #15
C-10 simplex
For anyone that gives a plop, dorman makes a repro pan with the stick going directly into the pan. This way you can pretty much run any SBC in any chassis with any exhaust manifolds:
http://www.dormanproducts.com/p-2022-264-118.aspx
The 78-(and 79?) malibus/elcaminos and i think monte carlos had this pan for emmission reasons i think?
You can clearly see in the picture that the stick goes directly into the pan.
