11-20-2012, 11:24 PM | #1 |
Tire sizes for Boss 338 and pics
Ok so I am thinking of running the chrome boss 338 rims on my truck. 20x8.5 front and 20x10 rear. What size tires do you use balsa if you have this set up I would like to see a pic. Thanks.
Posted via Mobile Device |
11-20-2012, 11:33 PM | #2 |
Re: Tire sizes for Boss 338 and pics
This isn't your year model but they have the rims and tires that you're looking for.
http://67-72chevytrucks.com/vboard/s...light=boss+338 |
11-21-2012, 12:01 AM | #3 |
I really don't know what size tires to use with 20 inch rims. i am currently running 235-70-15 (27.95 in height) on the front and 275-60-15 (27.99 in height) on the rear.
So i am thinking of running 20x8.5 Boss 338 on 245-40-20 tires. Ii just don't know what size for the back if I ran the 20x10 Boss 338. I want a little bigger tire just for a slight rake or close to even ride. |
11-21-2012, 01:42 AM | #4 |
245/40 in the front and 275/35 rears.
11-21-2012, 05:44 AM | #5 |
255/40/20 front
295/40/22 rear has 5/7 drop you can get 295/40/20 for rear if you go 20's all around....i went with coys to avoid the hub problem or running spacers. |
11-21-2012, 08:24 AM | #6 |
WHAT HUB PROBLEMS WITH THE 338s? I THOUGHT THEY WERE DIRECT BOLT ONS?
RIZ |
11-21-2012, 08:28 AM | #7 |
I thought that they fit directly on the hubs also. Someone explain please.
11-21-2012, 08:50 AM | #8 | ||
67-72 parts collector,…
Thru that time Boss modified the wheel to make them fit,... but they still didin't get it right. All you have to do is grind the "nose" of the 1-1/4" wide rotors and they will go right on. 1" Light Duty rotors were a bolt on from the very beginning. Look here: http://67-72chevytrucks.com/vboard/s...d.php?t=352320
11-21-2012, 11:30 AM | #9 |
This seems like more work than a little bit. I like the wheels but I am not trying to buy them for my truck and they never fit. I am confused right now on what I want to do. Are there any nice 20 inch wheels that directly bolt on with out any modifications.
11-21-2012, 12:26 PM | #10 | |
