Old 12-02-2012, 04:55 AM   #1
mexlokote
mexlokote's Avatar
sunvisor wiring?
so i bought my truck a roof top sunvisor at local junk yard, and installed some lights in it,
now my question is, does anyone know how i should wire this lights to make it turn on whenever i turn my lights?
is there any diagram? or someone can draw me one?
thanks
mexlokote is offline   Reply With Quote
Old 12-02-2012, 06:27 AM   #2
kikkegek
kikkegek's Avatar
Re: sunvisor wiring?
nice!
thing I would worry about the most is getting the wires into the cab, without causing a major leak in the future.
just wire them to the healights or running lights:
schematics can be found here:
http://forum.73-87chevytrucks.com/sm...?topic=11766.0
kikkegek is offline   Reply With Quote
Old 12-02-2012, 09:50 AM   #3
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
I would wire it directly to the parking lights... you can drill a small hole under the visor to accommodate the lights but youll have to silicone it well to avoid water leakage
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 12-02-2012, 09:50 AM   #4
J Knight
J Knight's Avatar
It looks like each light only has one wire for power so that means the light housing is self grounding but since you have them mounted on fiberglass they won't ground. You are going to have to hook one mounting stud on each light to a second wire and run it with the power wire to a ground inside the cab. Your going to have to drill a hole near the drivers side A pillar to run the wires into the cab to the fuse panel. There should be an unused terminal in the fuse panel to connect to for power to the cab lights.
John
82 Chevy Silverado 350ci/TH350
J Knight is offline   Reply With Quote
Old 12-02-2012, 11:02 AM   #5
motornut
78K & 79C Jimmys
motornut's Avatar
Yup!
Even seen a member use a blow gun to blow cotton string through the hole,top to bottom,to run the wire in the pillar...
and a member wired the outsides to work with his blinkers
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 12-02-2012, 01:23 PM   #6
CoggedBelt75
CoggedBelt75's Avatar
Originally Posted by motornut View Post
Yup!
That was Tx Firefighter. Here's his how to vid
Joe
__________________________________________
1975 C10
"Questions are a sign of intelligence indicating a desire to eliminate ignorance"
CoggedBelt75 is offline   Reply With Quote
Old 12-02-2012, 01:38 PM   #7
mexlokote
mexlokote's Avatar
thank u guys
Old 12-02-2012, 09:14 PM   #8
BLE 'BURBAN
In the Forgotten far North.
BLE 'BURBAN's Avatar
I wired up my outer clearance lights on my burb to flash with the turn signals.
1. Run a power wire to all lights from the parking lights.
2. Run a ground lead to the 3 center lights only.
3. Run a 2nd power lead from your rght side turn signal lead (Access this either under the hood and through the fire wall on the drivers side or under the dash if you can find the proper wire to tap into under there) an up to the far right clearnce lamp.
4. Run a 3rd power lead to the left side the same as you did the right.
5. Doing it this way no grounds are required for the 2 outer lamps for them to be operational.
I did this to mine 6 years ago and have had absolutely no problems with it what-so-ever.
1987 R3500 CREW CAB DUALLY (BIG RED)Acquired 06/12/2015
1990 chevy suburban V2500 5.7L
My cluster Mods-Nov 2007
overhead console Stereo install Round 2 Aug 2009
Heated/turn signal mirror upgrade
BLE 'BURBAN is offline   Reply With Quote
Old 12-02-2012, 09:55 PM   #9
BLE 'BURBAN
opps double post
Old 12-04-2012, 10:50 AM   #10
motornut
78K & 79C Jimmys
motornut's Avatar
yup thats a neat idea,I like it
John
