Old 12-02-2012, 12:29 PM   #1
old crewcab
4spd to 700r swap
hello, fellow truck members. I am in the process of starting a tranny swap. I've done the search function, but really could not find the answers I am looking for (if there is please post). OK here goes ... truck is a 84 gmc 2wd long bed 3/4 ton with a 4 spd (sm465?-3spd w/granny low). The rear end has removeable drums (not bolt on type). Now, here come the questions. Has any one done this swap? If so, what does this swap consist of ? I'm talking from end of crank to u-joint going into the rearend. Also cables, brackets, electronics, and mounts. THANK YOU for any info posted !!
old crewcab is offline   Reply With Quote
Old 12-02-2012, 02:59 PM   #2
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
Re: 4spd to 700r swap
After you remove all the SM465 parts, you need several parts.
Read this information: http://transmissioncenter.net/700R4_Swap_Info.htm
Grab a driveshaft from a LWB truck. You may need the transmission crossmember.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
gchemist is offline   Reply With Quote
Old 12-03-2012, 05:05 PM   #3
old crewcab
Thanks gchemist for the link, but not much info on 4 spd to automatic swap. Lots of useful info for other swaps. Any others out there with info? THANKS!!
Old 12-03-2012, 07:34 PM   #4
gchemist
gchemist's Avatar
For your particular swap, read this backwards.
http://coloradok5.com/forums/showthread.php?t=265119
First understand what is required for a 700R4. Then find what you have and what you need.
Old 12-04-2012, 09:07 AM   #5
77c10
77c10's Avatar
I would strongly suggest finding a crossmmember from a square that originally had a 700r4 in it. I just swapped one into my 77 in the place of a th350 and had to modify my crossmember to work.
77 C10, 6.0LS/4L80E, 3:73 12 bolt. Boss 338's 20" x 10" w/ 285/50/20 rear. 20" x 8.5" w/ 245/40/20 front. Vintage Air. Full Autometer gauges recessed in factory bezel (Thanks bigblock73!) Gm Storm Grey Metallic paint
"Cool ain't ever cheap and cheap ain't ever cool"
77c10 is offline   Reply With Quote
Old 12-08-2012, 09:41 AM   #6
old crewcab
anymore info out there? thanks!
Old 12-08-2012, 11:43 AM   #7
hatzie
Moderator
hatzie's Avatar
You'll need a steering column and OD shift indicator for your cluster.
You'll also need the linkage from the column to the transmission including the frame mount with the spring and plastic ball. The TH350 / TH400 linkages will work.
If you have the AT cooler in your radiator just pull the plugs out and install the lines. Most aftermarket radiators have them they're just plugged.
Get the tooth count from the Speedometer gears in your SM465. Someone more knowledgeable could tell you whether they use the same output gear or not.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 12-11-2012, 07:27 PM   #8
old crewcab
thanks hatzie, (or others) do you know if the front half of a driveshaft (from a truck with 700r) will mate to the rear half (my 3/4 ton shaft)?
Old 12-23-2012, 12:31 PM   #9
old crewcab
