12-04-2012, 02:50 AM | #1 |
L99/LT1 Intake?
I was browsing at my local pull-n-pay and saw a 90's Caprice with the L99(4.3 v8). From what Ive read these engines didnt make much power(200hp/245tq) but I also read some had the Lt1 intake manifold. Has anyone swapped one onto a 305 or gen I 350? I know Id need the harness but if its worth it Im sure I could get it for cheap.
12-04-2012, 04:48 AM | #2 |
Re: L99/LT1 Intake?
Trying to do fuel injection?
377 sbc thumpr cam autogear m23 muncie 3:73 Detroit trutrac 3''spintech prostreet mufflers xpipe 1 3/4 headers build thread !http://67-72chevytrucks.com/vboard/s...d.php?t=577217 Iroc gauge threadhttp://67-72chevytrucks.com/vboard/s...d.php?t=554511 |
12-04-2012, 06:42 AM | #3 |
Re: L99/LT1 Intake?
Yes, a baby LT1, a 3" stroke 305 block. They do have LT1 intakes on them. You do realize that you have to modify the bolt pattern drill and then epoxy or weld a dizzy mount & hold don and then use external crossovers for the coolant?
12-04-2012, 02:58 PM | #4 |
Re: L99/LT1 Intake?
Not worth the hassle IMO. You can pick up an entire LT1 with all accessories and wiring harness and put it in your truck for cheap.
12-04-2012, 04:12 PM | #5 |
Re: L99/LT1 Intake?
The internal ports are not the same from the "baby" setups, they're smaller. Same modifications apply though.
I've done a few of the conversions for TPI to LT1 intake swaps and they are easy, but from carbed or TBI to LT1 it's going to take a new harness. Score a TPI harness cheap and the rest is pretty easy actually. Here's a site that still hosts some of the write ups that I saw back in the early 2000's when I did mine. http://sethirdgen.org/LT1.htm You can even use the LT4 intake with Vortec heads using the same methods! EDIT: Oops, looks like most of those links are broken... Dang.
- 1981 Sierra 454, NV4500 swap - 2006 Z06, 25k miles - 1973 Nova - Project CarNova Virus on Youtube |
