Old 12-12-2012, 07:10 PM   #1
JFetter
Key won't come out of ignition - park lever issues
Hello,
My 78' Chevy ignition key is sometimes hard to remove from the ignition. It's an automatic, and when you put the shifter into park, that's not good enough. You have to take your other hand and literally pull the lever 'more' into park. (to the left)
Seems like not so much of an ignition issue, but rather a column shift issue?
I'm trying to get some ideas as to what parts I may need before I start this project.
Thanks.
JFetter is offline   Reply With Quote
Old 12-27-2012, 07:58 AM   #2
JFetter
Re: Key won't come out of ignition - park lever issues
Anyone?
Old 12-27-2012, 09:33 AM   #3
dieseldawg142
dieseldawg142's Avatar
have you checked to see if the shifter linkage is hanging up or binding anywhere? would be easier then tearing into your column
dieseldawg142 is offline   Reply With Quote
Old 12-28-2012, 09:23 AM   #4
ont_guy_38
ont_guy_38's Avatar
Seems like you just need to adjust your shifter linkage.
1985 C10
2004 Avalanche
ont_guy_38 is offline   Reply With Quote
Old 12-28-2012, 09:34 AM   #5
hyatt
check the bushings where the shift linkage hooks to column and transmission Check for any loose motion in linkage If no a simple adjustment to male shift rod longer should do the trick
1946 car hauler
1948 surburban
1937 chevy sedan
1940 olds sedan (project)
1967 ss396 chevelle
1999 dually crewcab(24000 miles)
hyatt is offline   Reply With Quote
Old 12-28-2012, 10:55 AM   #6
MDc10
MDc10's Avatar
I had the same issue just on my Chevy equinox, but it ended up being the tumbler in.the column. Im guessing all cars have tumblers. I could be wrong but I just wanted to toss that out there in case it is the tumbler. My key was stuck in the column there was no way to get it out. I ended up replacing the tumbler twice and that fixed it. Hope this helpers
MDc10 is offline   Reply With Quote
Old 12-28-2012, 04:19 PM   #7
slb1985
slb1985's Avatar
On my truck the tilt mechanism is loose again so the steering wheel moves up and down kinda freely and to go all the way into park I have to push the steering wheel up and it will fall into place. If you have the "chevy" tilt there is a write up to fix it ill find for you that will walk you through how to tighten the column up
1987 R10 Silverado - Rusty But trusty Daily
1984 C10 Custom Deluxe - Newest Project
slb1985 is offline   Reply With Quote
