01-10-2013, 06:14 PM | #1 |
rear window install?
im going to be installing my new rear window soon, what size string should i use to pull it in?
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308 2014 Chevy 2500hd duramax CCLB |
01-10-2013, 06:21 PM | #2 |
Re: rear window install?
I like 3/16 hollow braid nylon; 1/4 will work as well.
01-10-2013, 08:15 PM | #3 |
I use 1/8" nylon with plenty of creme hand soap, (no grit).
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
01-10-2013, 10:39 PM | #4 |
Dish soap on the rubber also works well . Anything you can imagine to make it slimy to help the rubber slide over the lip of the pinchweld. If you notice the rope start to really get tight stop before you tear the rubber that can happen. If you do get tight that means the glass is not centered in the hole and needs to shift over a little bit. Usally it will bump over just by going to the "long" side and bumping it with your hand. But in doing that be careful and don't break the handle out of that hammer. [that was a saying my dad has when someone hits something with their hands]
