Old 01-10-2013, 07:01 PM   #1
DropKick
DropKick's Avatar
Question Anyone ?
Is there any body with the 1/2 ton front 3/4 ton rear set up ? Just wondering thinking about doing this set up on my new c20. Anyone have Pictures? Thanks in Advance - DropKick McCracken
Thinkin Dirty Ridin Purdy
DropKick McCracken's Fleet:
1998 Chevy Silverado
1969 Chevy CST/10 Original paint
Comin soon: 1967 C10 short fleet
DropKick is offline   Reply With Quote
Old 01-10-2013, 07:34 PM   #2
69gmcc10
69gmcc10's Avatar
Re: Anyone ?
Are you thinking about changing the springs up front? Or are you going to change the spindle to 1/2 ton? what will you do with the bolt pattern mix them, 6 bolts front and 8 bolts rear? What will you do for a spare, carry 1 of each? Stacy Davids copperhead had a 14 bolt with a 1/2 ton pattern on them to handle the power of his drive train, that could e an option.
69 GMC C10 build thread- http://67-72chevytrucks.com/vboard/s...d.php?t=501676
03 Silverado build thread-http://67-72chevytrucks.com/vboard/s...d.php?t=591582
69gmcc10 is offline   Reply With Quote
Old 01-10-2013, 07:50 PM   #3
DropKick
DropKick's Avatar
Re: Anyone ?
i was thinkin about 5 lug fronts with a 8 lug rear but have 1 ton front and rear springs ,or buying 10 lug adapters and run a Super single commercial truck tire in rear and a 10 lug peterbilt rim on the front with the 1 ton springs ( i know if i go this route ill have to cut the bed up and mod the inner wells on the front not sure which route were going yet. See im a Ranch hand and i need a Heavy duty hauler
Old 01-10-2013, 07:58 PM   #4
69gmcc10
69gmcc10's Avatar
Re: Anyone ?
Things get complicated when you run 2 different bolt patterns, first you need 2 different spares. if you need a hauler and you want it on the cheep go with the 1 ton springs. if you want to be different go with the 10 bolt, for front inner fenders look into slosh tubz and see if they might work.
http://67-72chevytrucks.com/vboard/s...d.php?t=486039
