Old 02-12-2013, 08:11 PM   #1
RANDAL
RANDAL's Avatar
GMC headlight issue
Hey Guys having some trouble with my headlights on my 71 Jimmy. coming home from work last night the passanger low beam headlight went out. It works on the high beams so I'm guessing the bulds low beam went out so I switched them to high on the way home all 4 were working when I left my work but when I got home the high beam light was out (the inside light)and only the low beam bulb was working on high I hope this isnt confusing to anyone. if you can help that would be great.
RANDAL is offline   Reply With Quote
Old 02-12-2013, 08:15 PM   #2
TBONE1964
Cluster King
TBONE1964's Avatar
Re: GMC headlight issue
Check and make sure all of the grounds are clean and tight. Also check the connectors on the headlights themself and give them a clean and lube with dialetric (electrical) grease.
TBONE1964 is offline   Reply With Quote
Old 02-12-2013, 08:15 PM   #3
1972RedNeck
1972RedNeck's Avatar
Have you tried new bulbs? Have you checked and cleaned your connections?
1966 F250 4X4 416
1972 K20 350 4 OTF
Originally Posted by GASoline71 View Post
I once pulled an intake manifold for a cam swap... ended up with a full on drag car that ran in the 11's.
1972RedNeck is offline   Reply With Quote
Old 02-12-2013, 08:18 PM   #4
RANDAL
RANDAL's Avatar
I know I need one new bulb the low beam bulb And I haven't tried to clean them up will try that. would that make them stop working because they were working fine 2 days ago?
Old 02-12-2013, 08:26 PM   #5
TBONE1964
Cluster King
TBONE1964's Avatar
Try this:
Turn them on with the brights and wiggle the connectors where they plug into the headlights and see what happens. Next try the same thing with the grounds. If nothing happens, then with your fist, give the headlight a wack and see if it comes on or goes out. If yes, then the headlight filaments are broken and just barely making a connection.
Old 02-12-2013, 08:29 PM   #6
RANDAL
RANDAL's Avatar
Originally Posted by TBONE1964 View Post
Try this:
Thanks I will try this out and see if that works I have wiggled the wires a little bit but only on th low beams but I will try it agian.
Old 02-12-2013, 09:20 PM   #7
Sideways
Sideways's Avatar
You can also check the connections on the floor dimmer switch.
Sideways is offline   Reply With Quote
Old 02-13-2013, 12:34 AM   #8
RANDAL
RANDAL's Avatar
Thanks for all the help guys I found out the problem my low beam bulb was bad and also my high beam bulb was bad. Thanks.
