02-20-2013, 11:55 AM | #1 |
Sound deadner
What have you guys used for sound deadening in your cab? There are so many choice out there that I'm just looking for the best bang for the buck
My name's Tim and I'm a truckaholic My 56 Chevy shop truck build http://67-72chevytrucks.com/vboard/s...d.php?t=562795 |
02-20-2013, 12:46 PM | #2 |
Re: Sound deadner
Fat Mat off Fleabay. I have used several brands including Dynamat and also wanted a less expensive option. Fat Mat XXX Extreme actually sticks better than the Dynamat. Works awsome.
02-20-2013, 12:56 PM | #3 |
Re: Sound deadner
How does it compare on price?
02-20-2013, 04:40 PM | #4 |
Re: Sound deadner
Waaaay cheaper, to the point I have ordered it again for my next build I'm working on
02-20-2013, 05:57 PM | #5 |
Re: Sound deadner
look up "ezcool" insulations. works good for insulating heat and sound. I like it and use it in evertything. I just use 3m super77 adhesive and stick it where ever I need it
___________________________ 1959 Apache Short Fleetside, 1959 Apache NAPCO Long Stepside, 1957 3100 with 59 fleetside bed 1957 5700 LCF Crew Cab "Big Bertha",1959 GMC F370 1958 GMC 600, 1946 Chevy, 1959 Viking 60 LCF 1974 Elcamino SS, 1979 6500 GMC Tilt Bed Wrecker Big Bertha Build Last edited by buggy5872; 02-20-2013 at 06:02 PM. |
02-20-2013, 06:00 PM | #6 |
Re: Sound deadner
Newfisher, how is the quality?
I want something that will quiet the cab down to the point I don't hear anything unless I stomp on the engine. (I know it's unrealistic, but I'd like to get as close as I can.) |
02-20-2013, 06:11 PM | #7 |
Re: Sound deadner
I was very surprised. i didn't cut it into strips and strategically place them, I covered the whole floor, fire wall ,roof, inner doors ( at an angle to shed water) and rear panel. I then tape all of the seams with aluminum foil.
02-20-2013, 07:21 PM | #8 |
Re: Sound deadner
I may as well be the one to post it: The best bang for buck is Peel 'N Seal from Home Depot or Lowes.
Someone will inevitably chime in and say it smells in the heat. It doesn't but you don't have to take my word for it. Search here, search the HAMB, Google it. There are LOTS of guys who swear by it including guys from very hot weather areas like Phoenix. Posted via Mobile Device |
02-20-2013, 08:25 PM | #9 |
Re: Sound deadner
Peel Seal and Fat Mat are about the same price if you shop around. I used the Fat Mat stuff and it worked well.
02-20-2013, 08:41 PM | #10 |
Re: Sound deadner
yeah well, it only gets hot up here a few days out of the year and that's into the 90's. Nothing like Phoenix. I forgot all about the peel and seal discussion on the HAMB, thanks Dan
02-20-2013, 08:52 PM | #11 |
Re: Sound deadner
Fatmat might be slightly more money but I just wasn't willing to take the chance on my project getting something from Home Depot that I couldn't completely trust. I live in So. AZ and that smell is a scary thought.
02-20-2013, 08:56 PM | #12 |
Re: Sound deadner
NEWFISHER curious as to what you mean by "at an angle to shed water". I have a 51 that I plan to cover the inner doors and they don't appear to have much of an angle on them.
02-20-2013, 09:24 PM | #13 |
Re: Sound deadner
http://www.ebay.com/itm/FatMat-50SqF...e5a6e1&vxp=mtr
90 bucks for 50 sq ft http://www.homedepot.com/p/t/1005943...9#.USV1lh04vqE 17 bucks for 12.5 sq ft = 68 bucks for 50 sq ft The more you buy the cheaper the Fat Mat is per square foot. I bought 100 for 150 bucks which is only slightly more expensive per foot. |
02-20-2013, 09:54 PM | #14 | |
Re: Sound deadner
02-20-2013, 10:05 PM | #15 | |
Re: Sound deadner
02-20-2013, 10:09 PM | #16 |
Re: Sound deadner
check out my profile I have a picture in it, of when I was installing it.
02-20-2013, 10:49 PM | #17 |
Re: Sound deadner
Check out this stuff:
http://www.raamaudio.com/ I've read good things about it and it's nowhere near as expensive as Dynamat. It is butyl based not asphalt. I've had some real bad experiences with asphalt sound deadners-not sticking to panel after a few months and melting during summer months. Real "ugly"! |
02-20-2013, 11:03 PM | #18 | |
Re: Sound deadner
http://www.stevemeadedesigns.com/boa...hts-on-fatmat/ This guy says Fat Mat and Peel & Seal are the same stuff. Goes on to talk about asphalt based deadners being inferior as I found out the hard way. I did a brand new F150 a few years ago with an asphalt based deadner, removed the door panels about 9 months later to find that 75% of it had released from the panels and was just hanging there. |
02-20-2013, 11:14 PM | #19 |
Re: Sound deadner
I never had any odor in my truck but the leather, could not smell the P&S, must have been another brand, Seven years later still no bad odors!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
02-20-2013, 11:50 PM | #20 |
Re: Sound deadner
For anyone considering Peel 'N Seal, the link Garys8 posted above to the Home Depot stuff is NOT Peel 'N Seal. I don't know if they've stopped carrying it and I don't know how much it has in common with P&S. I only know that all of the guys on the HAMB that said they had good results with it used the real-deal Peel 'N Seal.
If you use something "similar" you should not be surprised if you don't get the same results. Maybe Lowe's still carries it(?) Personally I'd be completely comfortable using the real stuff but would not use this other stuff. |
02-21-2013, 12:05 AM | #21 |
Re: Sound deadner
pretty interesting
Just some food for thought. http://www.sounddeadenershowdown.com/cgi-bin/index.cgi |
02-21-2013, 12:15 AM | #22 | |
Re: Sound deadner
02-21-2013, 12:26 AM | #23 |
Re: Sound deadner
I was wondering how that was going to work inside the doors. I'm still planning on using a combination of materials depending the area of the car it's in. I've suffered through too much noise and too much heat or cold getting in for way too long and would like some level of comfort this time.
02-21-2013, 12:34 AM | #24 | |
Re: Sound deadner
02-21-2013, 01:45 AM | #25 |
Re: Sound deadner
