02-22-2013, 04:57 PM | #1 |
Headlight bezel help.
Could anyone tell me what these headlight bezels might be from.
Thanks. Posted via Mobile Device Posted via Mobile Device Posted via Mobile Device |
02-22-2013, 11:53 PM | #2 |
Re: Headlight bezel help.
Are they different than AD lights bezels?
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD) 53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25 55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73 62 Solidaxle Corvette Roman Red (327 340hp 4spd 3:36) C4 & C5 suspension tube chassis LS 3 4L70E 65 Corvette Coupe 327 350hp 4spd 4:11 78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42 2000 S-Type 3.0 (wife cruiser) 2003 GMC SCSB 5.3 4L60E 3:42 |
02-23-2013, 12:44 AM | #3 |
My headlights on my truck stick out farther than my bezels. The bezels in the picture are longer/wider and sit flush with the bulbs.
Here is another truck with different bezels that are longer Posted via Mobile Device Posted via Mobile Device |
02-23-2013, 12:46 AM | #4 |
This is what my headlights look like on my truck.
These are all pictures of trucks I've found on the site I hope it's ok to repost them. Posted via Mobile Device Posted via Mobile Device |
02-23-2013, 01:31 AM | #5 |
optomistic ah-so
I can't ID those exact ones, but '54 Dodges and Plymouths used similar (but longer) headlight rings to give their '53 sheetmetal an updated "deeper" or frenched look. I'd imagine any bodystyle that had been around long enough to see the frenched headlight trend would have a similar headlight ring by the mid-50's. The first place I'd look are the '53 Chevy & Pontiac sedans, for example.
Rubbing is Racin' Ribbing is Bench Racin' 1970 C-10 lwb Fleetside. Originally 350 2-bbl 3-on-the-tree, m/b, m/w, m/s no a/c. Currently running on a '76 Camaro 305. |
02-23-2013, 12:15 PM | #6 |
I would say the ones you have are the stock one's and the one's off the truck you posted are from another car or truck..
02-23-2013, 02:34 PM | #7 |
CSGAS. Thanks for all the info. Ill start looking for what I can find.
@Parkwood. I knew they were off another car but just trying to narrow down which ones. Posted via Mobile Device |
02-23-2013, 02:49 PM | #8 |
I have the same problem and am looking for some early Plymouth rings
02-23-2013, 04:30 PM | #9 |
They could be Plymouth or Dodge from the early 50's or could be 51 Ford Car.
53 Dodge 51 Ford
02-23-2013, 08:31 PM | #10 |
pfttt... only 2 headlites?
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
02-23-2013, 08:44 PM | #11 |
Maybe were old but we only need 2 eyes !!
02-23-2013, 09:17 PM | #12 |
02-24-2013, 12:43 AM | #13 |
and good Phillips bulbs with a full 12VDC switched through a relay, helps !!!
02-24-2013, 01:09 PM | #14 |
Those relays really save on switches when you run Halogen lights with high watt bulbs. I wouldn't build another car or truck without them. With the 55/100 watt H-4 bulbs in my 71 I was burning out a dimmer switch every three months until I added relays.
