Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > The 1960-1966 Chevrolet & GMC Pickups Parts Board
Old 05-19-2013, 03:20 PM   #1
stsalvage
Scrapper 1
stsalvage's Avatar
Not sure if any of you go into the wanted area
any of you have a donor truck that your about to junk I need the rear frame mounts for a 1963--66 1/2 ton its the one with the ribbits and I need the rear one's that have the rubber biscuit and had the long bolt that goes up throw the frame want factory ones no aftermarkets stsalvage@yahoo.com converting a 1965 1 ton to 1/2 to and have them yucky strange mound in the rear of the cab
stsalvage is offline   Reply With Quote
Old 05-20-2013, 01:15 PM   #2
1963c-10
1963c-10's Avatar
Re: Not sure if any of you go into the wanted area
I have a 64 frame that I'll check out, but I believe they are already removed. I have a 61 frame also that does have them, but you want 63-66 specific. Ill let you know when i get home.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 05-20-2013, 10:29 PM   #3
travz500
travz500's Avatar
well if he falls thru and his are gone I am pretty sure I have a set ready to be cut off if you need them
travz500 is offline   Reply With Quote
Old 05-21-2013, 09:15 AM   #4
1963c-10
1963c-10's Avatar
Yeah, I only have the 61 mounts left. Check w/travz500...he has them.
Old 05-21-2013, 12:12 PM   #5
Daking19
"please register with site in order to post for sale or wanted ads.."
Daking19 is offline   Reply With Quote
Old 05-21-2013, 02:43 PM   #6
BLK65K10
stsalvage I have some removed if travz500 doesn't have any. Thanks Lyle
BLK65K10 is offline   Reply With Quote
