Old 06-15-2013, 03:58 PM   #1
BTMDOUT
Grille question
Will the grille and headlight bezels off of an '89 crew cab fit an '83 regular cab without changing the radiator support?
BTMDOUT is offline   Reply With Quote
Old 06-15-2013, 06:45 PM   #2
SamsAutoParts73-87
SamsAutoParts73-87's Avatar
Re: Grille question
You need the rad support, lower grille filler panel, headlight mounts, marker lights, grille and headlight bezels of course, and the 89 headlight harness spliced into your original harness.
My 79 currently has an 89 K5 front clip on it. Its a nice upgrade if you can get all the parts you need and a day to do it.
-Sam
1987 Chevy R30 CC 454/4spd Work Truck
1979 Chevy K10 SWB 350/4spd/NP205,
1979 Chevy C10 LWB 350/TH350 Project
1981 Chevy K30 350/Th400/NP205
1986 Chevy K30 CUCV 6.2L/TH400/NP208
SamsAutoParts73-87 is offline   Reply With Quote
Old 06-19-2013, 10:35 PM   #3
slash crashley
lucky knuckles
slash crashley's Avatar
Exclamation Re: Grille question
safe to assume, one would also need the radiator support to go from an 83 (single headlight) to an 87 stacked headlights?
after the rad support is obtained, I'd just need headlight doors and headlights right?
(I plan on reusing the existing billet grill in there now) I've been scouring craigslist and local yards looking for the complete assembly but haven't had much success.
Rock Auto wants $92 for the support and $91 to ship it.
slash crashley is offline   Reply With Quote
Old 06-20-2013, 02:13 PM   #4
BTMDOUT
Re: Grille question
As far as I can tell, and the research I have done, you are correct. You might check on e-bay for a rad support, that's where I found mine. Good luck.
