06-17-2013, 10:27 PM | #1 |
83 c-30 -out wdana 60 in w/ 14 blt ?
ive got a 83 chevy c-30 dually w/a dana 60 ! will a say 1980s -14 bolt bolt in ? same width ? {i have a cab & chassis car hauler}mine is a 4:10 /w a diesel -6.2 /automatic,thinking maybe a 3:73-14 bolt ??? any ideas ?thanks mike
06-17-2013, 10:52 PM | #2 |
Charlie Daniels w/ a Tq Wrench
Re: 83 c-30 -out wdana 60 in w/ 14 blt ?
Are you sure it's a D60 and not the bigger stronger heavier Dana 70HD? It should have the 70 factory installed, not a 60, nor a 14FF (14FFs were in SRW trucks) Hint, they share the same cover as the Dana 60, but everything else is bigger and comparable in strength or better to a 14 Bolt Full Floater.
ΜΟΛΩΝ ΛΑΒΕ 67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works69 K5 Blazer-Family Beach Cruiser Project 78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s |
06-17-2013, 11:58 PM | #3 |
My 87 C30 cab-n-chassis had a 14 bolt in it. But if you have a C & C 14blt then it will bolt right in.
------------------------------------------------------ -Lance 2000 Chevy C2500, 5.7, 4L80e 1999 Suburban K2500, 7.4, 4L80e 1980 Camaro..son's car...PROJECT |
06-18-2013, 12:48 AM | #4 |
your tuck should have a 70hd in it, measure the axle tubes
"DON'T TOUCH THE TRIM!!"-Early Kyler |
06-18-2013, 05:58 AM | #5 |
Re: 83 c-30 -out w/dana 70 in w/ 14 blt ?
it probably is the 70h but its got some problems ,might need a rebuild down the road,thought id look for a later model 14 bolt to install later ?,if its a easy bolt in ? possibly have to do u-joint modification ?
06-18-2013, 07:53 AM | #6 |
You are correct, a cab and chassis would have a 14 bolt typically, while regular duallys would have the Dana 70HD. A 73-87 C&C 14 bolt would be a direct bolt in, but may be too narrow if you currently have a dually width Dana 70. You could also bolt in a SRW 14 bolt, it is a little wider than a C&C, but not as wide as a dually axle. As far as later axles, I am not positive, but I think the later 88+ model 14 bolt dually axles have a wider spring perch spacing, so you may have to cut and weld new perches on. Also note, 3/4 ton SRW 14 bolts have wider perch spacing as well.
06-18-2013, 09:14 AM | #7 |
