Old 06-29-2013, 04:26 PM   #1
nele22
New wheels and tires
I finally broke down and ordered my wheels and tires. I went with the Cragar Classic 69 series wheels 15x8 square set up. For tires I ordered Cooper Cobra GT 245/60 front and 255/60 rear. Also added the 3" port-o-walls.
The spider caps that Cragar sells for the wheels are only available in 5 lug. Since I am still 6 lug I went with the Gorilla Bullet centers with matching bullet lugs.
nele22 is offline   Reply With Quote
Old 06-29-2013, 04:29 PM   #2
nele22
Re: New wheels and tires
Old 06-29-2013, 11:03 PM   #3
808_67C10
808_67C10's Avatar
Cant wait to see umonthe truck... Curious how the port-a-walls holdup.... Heard good and bad about them.
Frank (Hilo, Hawaii)
Trucks, Tacos, and Beer go together like Peanut Butter and Ladies!
85 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=760383
67 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=489298
79 K5 Blazer SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=657461
808_67C10 is offline   Reply With Quote
Old 06-30-2013, 01:41 AM   #4
67ctener
67ctener's Avatar
Love the wide whites. Get them on the truck and upload pics, maybe even one with a pin up girl would be nice
Scott
67 c10 sold
89 c1500
90 k2500
91 s10
#chevyonly
67ctener is offline   Reply With Quote
Old 06-30-2013, 11:56 PM   #5
nele22
Well I have been working on the Fauxtina this weekend. I got the wheels and tires on. Installing a DJM 5/5 drop this Weds.
Old 07-01-2013, 12:04 AM   #6
TrixR4Kids
TrixR4Kids's Avatar
Can't wait to see how it looks lowered.
~ Dave
'68 C10 Stepside: 350/700R4
TrixR4Kids is offline   Reply With Quote
Old 07-01-2013, 03:35 PM   #7
nele22
Me either!
Old 07-01-2013, 06:06 PM   #8
ecgate
ecgate's Avatar
Subscribed. Lets see that drop.
ecgate is offline   Reply With Quote
Old 07-01-2013, 10:22 PM   #9
nele22
Springs and blocks came today. Already have the shocks. Just waiting on the control arms.......
Old 07-01-2013, 10:48 PM   #10
catch2otwo
what is a porta wall?
catch2otwo is offline   Reply With Quote
Old 07-02-2013, 07:24 AM   #11
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
It's a fake whitewall. You put them on your black wall tires when you're mounting them to get the whitewall look.
They have been around for 50 years or more. Cheap way of making any tire into a wide white.
They do have their downsides too though.
Old 07-02-2013, 12:13 PM   #12
nele22
Correct. I have run them on several vehicles. Although they are not perfect they are a very inexpensive option to traditional whites.
Old 07-02-2013, 12:16 PM   #13
TrixR4Kids
TrixR4Kids's Avatar
Where did you get the porta walls and bullet caps?
~ Dave
Old 07-02-2013, 11:41 PM   #14
nele22
Port-o-walls from Lucas Tire
http://www.ebay.com/itm/15-x3-Portaw...item338345eff4
Summit Racing for the bullets. They have two different center bore sizes. Mine are the 4.25
http://www.summitracing.com/parts/gor-hc216bt
Old 07-03-2013, 01:10 AM   #15
catch2otwo
Ooooh, learn something new everyday
Old 07-03-2013, 11:18 AM   #16
808_67C10
808_67C10's Avatar
Looks sick!!! The drop is gonna set it off!
Old 07-03-2013, 07:02 PM   #17
Pro Performance
Pro Performance's Avatar
Nice.... I like it!
Pro Performance is offline   Reply With Quote
Old 07-03-2013, 10:29 PM   #18
808_67C10
808_67C10's Avatar
I think I am gonna go that route with my steelies.
Old 07-03-2013, 10:56 PM   #19
CSGAS
optomistic ah-so
CSGAS's Avatar
The most common complaint about Porta-walls is how they yellow and crack over time. You're very likely to change your wheels and tires before it happens. Some patina admirers might even appreciate seeing aged Porta-walls instead of white ones.
If you want to stretch out their life though, DON'T use silicone protectant (most tire shine, dashboard products). You need to kill the effects of UV. Try a real wax, again not silicone, but the polymers are OK while earlier formulas let them "breathe" better. You may prefer neutral shoe polish, or even painting over it with a craft store semi-gloss clear coating for preserving artwork.
Rubbing is Racin'
Ribbing is Bench Racin'
1970 C-10 lwb Fleetside. Originally 350 2-bbl 3-on-the-tree, m/b, m/w, m/s no a/c. Currently running on a '76 Camaro 305.
CSGAS is offline   Reply With Quote
Old 07-04-2013, 03:02 PM   #20
nele22
Lowering kit is on. It is not level however. Looks like I have more work to do. The driver side is roughly two inches lower than the passenger.
Old 07-04-2013, 03:08 PM   #21
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Truck looks good with the white walls and black smoothies.
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 07-04-2013, 03:10 PM   #22
Tx Firefighter
Check that you have both front springs clocked properly. The end of the bottom loop should set into the control arm in the little groove made for it.
Also make sure your upper ends of both coils are seated in the upper mounts. Both springs should be located in the middle of the round cutout in the crossmember. Usually a pry bar or even driving it a bit for a few blocks will seat them. You'll hear a pop noise and feel it settle into place.
Old 07-04-2013, 03:13 PM   #23
nele22
I am hoping you are right. Frustrating!
Old 07-06-2013, 06:39 AM   #24
Boog
laying low
Boog's Avatar
Nice improvement with the drop. A little fine tuning and it'll be set.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 07-06-2013, 03:02 PM   #25
70cst
70cst's Avatar
Very nice. Great look
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
