07-01-2013, 08:02 PM | #1 |
Will factory center vent work with vintage air unit?
Like the title states. Can someone answer this for me please.
Thanks, Tim Posted via Mobile Device |
07-01-2013, 09:16 PM | #2 |
Re: Will factory center vent work with vintage air unit?
I believe it will, the kits are designed to use the existing vents.
Scott 87 Chevy 2WD SWB, 88 4x4 LWB http://67-72chevytrucks.com/vboard/s...d.php?t=610652 |
07-01-2013, 09:30 PM | #3 |
Yes, you use the factory vent, with the vent connection that VA uses in the kit, there is a marked increase in the volume of air that comes out of that vent.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
07-01-2013, 09:31 PM | #4 |
I don't have a factory ac dash. The PO cut the sides for the vintage air vents but not the center vent. I think the kit is supposed to come with a center vent but I didn't get one with the truck. I'm looking for ideas so I can keep both sides of my body cool in this Texas heat
07-01-2013, 09:32 PM | #5 | |
07-01-2013, 09:36 PM | #6 |
If you can't find OEM, the repops (Brothers) of this part is very nice.
07-01-2013, 09:59 PM | #7 |
Thanks for the heads up
07-02-2013, 12:22 AM | #8 |
2WD Jimmy
You can get that vent from VA. I can't remember if my kit came with it or not. My kit blows way better than the original did though.
07-02-2013, 01:01 PM | #9 |
I ordered the assembly from vintage air. Thanks for the help
07-02-2013, 04:12 PM | #10 |
Center vent works great. My truck was not factory air and I cut the vent hole w/ an air tool & cutoff wheel. Get ready to stand on your head to get it all in there. The plenum on the back goes in and the bolts that hold the center vent in place go into blind holes - screwed in from the rear. I swore after wrestling it in there against the dash speaker bracket that if something ever went South I'd just have to do without it! When I attached the duct to it I cinched it w/ a wire tie and prayed it wouldn't blow off when the fan came on!
07-02-2013, 04:41 PM | #11 |
Devil's in the Details
I bought all the center vent items from the aftermarket (non front A/C, had to cut holes) and it works great with my GenIV unit.
'70 K10 Suburban - TBI 454, 4L80E, NP241C, Dana 60 & 44 - The 10+ Year Project Thread Datsun 240Z, 510 2 door and an old Honda motorcycle |
07-02-2013, 05:56 PM | #12 |
lookee there. There weren't blind screws, it was those studs like that. What is it they say... 'memory is first to go'? darn. |
07-02-2013, 10:45 PM | #13 | ||
07-02-2013, 11:10 PM | #14 |
Can't speak for Beelzeburb as to where he got it... but that is exactly what you will get in the mail from VA. Mine is great, but the center vent blows most of it's air on the driver because of the way the air comes in from the passenger side into the vent.
I never dreamed my VA would cool as good as it does. Yes, on a 101deg day it works to keep up, but most times it does keep me comfortable with ease. I insulated my floor plan and tinted my window.... glad I did now. |
07-04-2013, 10:47 AM | #15 |
I got my parts from Brother's. I tapped the back of the housing and cut some all-thread to the right length for my install. Like stexag said, because the air comes from one direction with the upgraded housing, it mostly blows right on the driver. Of course, the front seat passenger is free to snuggle up to the driver all she wants.
