Old 08-23-2013, 04:26 PM   #1
bigmac73
bigmac73's Avatar
slip joint style shaft
have any of you guys on here upgraded to a slip joint style 2 piece drive shaft? and what were the results, found a local guy that will build me a 3in diameter 2 piece slip style with all 1350 series joints for about 700.00 , new yoke and pinion yoke .
i know Denny's use to build them but they discontinued that model for out style of trucks
72 C-10 LWB Cheyenne
Vortec 355 /TH 350
bigmac73 is offline   Reply With Quote
Old 08-23-2013, 05:27 PM   #2
brad_man_72
the boat guy
brad_man_72's Avatar
Re: slip joint style shaft
Leaf spring trucks came with them, and still come with them in every make of full size truck.
The reason the coil spring trucks didn't "need" a slip in the rear shaft is because the control arms are about the same length as the rear shaft so the lenght of the rear shaft didn't need to change as the suspension cycled. That's why the light duty carrier bearing has a very soft rubber, to let the shaft move foreward and back the small ammount that it will.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck
66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate.
28, model a rpu project,
brad_man_72 is offline   Reply With Quote
Old 08-23-2013, 05:29 PM   #3
brad_man_72
the boat guy
You have a lwb, you can have a one piece made for a lot less, as long as theirs no clearance issues with your crossmember. I know lowered trucks clear just fine.
Old 08-23-2013, 08:22 PM   #4
bigmac73
bigmac73's Avatar
I have read about the one piece shafts in the past having vibration issues
during high way speeds???
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
Old 08-23-2013, 10:21 PM   #5
DKclassis72
i just got mine back. upgraded aluminum/poly carrier bearing and slip/stub on the rear section. got around $450-500 in it with reusing the front tube and everything else new. new yoke, joints, etc. Have a 100 or so miles on it and no complaints.
DKclassis72 is offline   Reply With Quote
Old 08-23-2013, 11:18 PM   #6
jjzepplin
jjzepplin's Avatar
http://4xshaft.com/ This guy does not play fair...
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 08-24-2013, 07:09 AM   #7
bigmac73
bigmac73's Avatar
Did he upgrade the tube size to 3 inch? the tech on the phone was telling me that if i went to 1350 series joints i would have to upgrade to a bigger tube size?
Mike
Old 08-27-2013, 08:32 PM   #8
El Campo
El Campo's Avatar
I had a 3 inch one piece built (but it is for a SWB) with 1350 Spicer yoke and U joints for about 350 at Houston Drivetrain (local shop).
72 Chevy blue LWB, 99% original Oklahoma truck, 28,000 miles
72 Chevy SWB: http://67-72chevytrucks.com/vboard/s...d.php?t=486626 (Attempt/Mistake #2)
2003 Harley Davidson Dyna Superglide with 2007 Street Bob front end
2000 Ford F350 Powerstroke 4WD CCLB, 310,000 miles running great (STOLEN St. Patricks Day 2014 AND NEVER RECOVERED)
2002 Ford F250 Powerstroke 4WD CCLB (To replace stolen one)
Hook em Horns!!!
El Campo is offline   Reply With Quote
Old 08-27-2013, 09:48 PM   #9
DKclassis72
yes Bigmac73, I believe it is a 3" rear tube
Old 10-11-2013, 08:57 PM   #10
BCOWANWHEELS
my truck is dropped 5/7 and i have a slip yoke d/s for mine (2 piece) it did "not" help in stopping carrier bearing breakage. if you want to buy it as a assembly i,ll make you a deal and i,am fairly close to you.
bob
1-423-384-8938
I BELIEVE IN JOHN 3:16
BCOWANWHEELS is offline   Reply With Quote
