Old 08-27-2013, 12:55 PM   #1
White70C20
White70C20's Avatar
Lifted 2wd?
Has anyone here ever lifted a 2wd truck? I know I'm probably in the minority, but I really don't like the look of lowered trucks (sorry). My '70 C20 has stock suspension on it now, and when I pull up beside newer 2wd trucks, even 1/2tons, they're all sitting up higher than I am.
I know one of Chevy's major selling points was that their trucks sat lower than the competition, thus making them ride more like a car. But nowadays, even modern sedans ride higher than they did back 40 years ago.
My question: has anyone lifted a 2wd truck? If so, what did you use? I'm not looking for a huge lift so I can fit 35s under it, I just want to sit up higher on the road.
White70C20
1970 Blue C20 - 250, 4 speed
1985 Ford Thunderbird
2005 Pontiac G6
White70C20 is offline   Reply With Quote
Old 08-27-2013, 02:05 PM   #2
Mr Chevorlet
Rusty Nuts
Mr Chevorlet's Avatar
Re: Lifted 2wd?
They used to make twist in coil spring spacers that would give you a little lift but not much. it would keep your springs from collapsing so much. I had them on my 67 in the 80's.
(Clever Missouri) Southwest
Larry
Mr Chevrolet
My Build, The Marathon Truck
http://67-72chevytrucks.com/vboard/s...d.php?t=604414
Mr Chevorlet is offline   Reply With Quote
Old 08-27-2013, 02:53 PM   #3
etindoll
Re: Lifted 2wd?
I think they make spacers that will go under your front springs to give you about an 1-1/2 of lift. I think I have heard some people using Jeep coils in the back maybe these could work.
http://www.carid.com/1998-jeep-wrang...Fc5FMgod4DkAag
etindoll is offline   Reply With Quote
Old 08-27-2013, 03:28 PM   #4
White70C20
White70C20's Avatar
Re: Lifted 2wd?
Thanks, guys!
I forgot to mention some vital information. My truck is a 3/4 ton with the "Custom Camper" package. It has heavy duty leaf springs in the back. (I'm assuming most 4x4s had leaf spring rear ends too?)
Basically, I was wondering if a lift kit for a '67-72 K20 would fit on my C20? Or if anybody had had luck swapping in different components to make them higher.
White70C20
2005 Pontiac G6
Old 08-27-2013, 05:16 PM   #5
Bigdav160
Bigdav160's Avatar
Re: Lifted 2wd?
The rear is easy. With leaf springs you can run blocks, or lifted springs or a shackle flip.
The front is more of a problem. 4WD trucks had leafs in the front also.
How about a small body lift?
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 08-27-2013, 06:47 PM   #6
slow-1
slow-1's Avatar
Re: Lifted 2wd?
You are not alone...someone just asked about raising the front of his C-20...front springs from a 73-87 crew cab dually was suggested.
http://67-72chevytrucks.com/vboard/s...d.php?t=594365
1972 Cheyene C-10 "Ole Green"
My Grandfathers truck (early 70's to 1983)
My first vehicle (1983)
Original 350 (3 rebuilds)
700R4 from Bowtie Overdrives
slow-1 is offline   Reply With Quote
Old 08-28-2013, 11:58 PM   #7
White70C20
White70C20's Avatar
Re: Lifted 2wd?
Thanks guys,
That's great 'n all, but what I'm after is making my C20 the same height as a more modern 3/4 ton 2wd. My grandfather has a '95 C2500 (basically the same as mine only 25 years newer) and it sits up significantly higher than mine. Granted, it's only 18 years old and only has 58,000 miles, vs. my 43 year old truck with 68,000 miles.
Am I just asking too much from old technology?
White70C20
2005 Pontiac G6
Old 08-29-2013, 01:34 PM   #8
nightmare
nightmare's Avatar
Re: Lifted 2wd?
Stock height these things weren't but 33"-35" from the ground to the top of the fender well. What's yours sitting at now?
Mike
2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip
1972 Chevy Suburban - Turquoise/Black
1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD
Using your turn signal is not "giving information to the enemy"
67-72 FAQ
Originally Posted by GMCMAX View Post
My lugnuts require more torque than your honda makes!
nightmare is offline   Reply With Quote
Old 08-29-2013, 02:28 PM   #9
steelhorse
steelhorse's Avatar
Re: Lifted 2wd?
Try buying a new set of springs for a big block truck. Your springs have probably settled a couple of inches over the years.
steelhorse is offline   Reply With Quote
Old 08-29-2013, 02:49 PM   #10
Lou Boffa
Lou Boffa's Avatar
Re: Lifted 2wd?
may not be what you are after but 16" steelies and a 235/85 will raise the stance
Figure out what you want--then figure out what you are willing to give up to get it.
Lou Boffa is offline   Reply With Quote
Old 08-29-2013, 03:07 PM   #11
ksshane
ksshane's Avatar
Re: Lifted 2wd?
I could be wrong but I think he is looking for something even taller. Probably some way to get his suspension high enough to put some 35" tires under there and still have plenty of room.
The rear would be pretty simple with leafs in the rear. Front is more of a challenge. May have to look at some newer trucks and their front suspensions to see if any can be swapped out. I remember in the 90's seeing alot of aftermarket parts in the magazines to raise 2wd trucks.
I know.. probably no help at all
71 swb 350/4sp manual 5/7 static drop
ksshane is offline   Reply With Quote
Old 08-29-2013, 03:23 PM   #12
SS Tim
SS Tim's Avatar
Re: Lifted 2wd?
There is about an 8" difference in curb height between a 72 and a 2012. Much of that is the cab interior height and the fact the floorpan sits pretty much flat on top of the wider frame. Trying to raise the truck that much is going to be costly to have it done right and still ride like a street truck. A set of taller front springs, rear blocks and 33" (255-85R 16 for example) tires should do a lot without killing the ride.
SS Tim is offline   Reply With Quote
Old 08-29-2013, 03:28 PM   #13
Pro Performance
Pro Performance's Avatar
Re: Lifted 2wd?
Here is a write up of a forum member (Dino) who change the ball joints to accept a later model lift spindle. In my opinion, this would be the ideal way to go, since it won't effect ride at all. You can also put a lift springs in there also to get additional height, like he did. He is using the 88-98 Chevy truck lift components.
Hope you find this link helpful.
http://67-72chevytrucks.com/vboard/s...d.php?t=282398
Pro Performance is offline   Reply With Quote
Old 08-29-2013, 03:29 PM   #14
Pro Performance
Re: Lifted 2wd?
Here is another on a square body.... same idea.
http://67-72chevytrucks.com/vboard/s...d.php?t=469743
Old 08-29-2013, 05:03 PM   #15
White70C20
White70C20's Avatar
Re: Lifted 2wd?
Cool, thanks guys!
I was out looking at my grandfather's old '70 C20 he parked in amongst the other old farm machinery he didn't use anymore. Though it's sunken down into the dirt a little bit over the last 25 years, it seemed to me that the distance between the top of the wheel well and the tire is about the same as my truck (the two are virtually twins). I want to drag it out and get a good look at it sometime. It has a 250 I6 in it, where mine has a 350 so mine could be sagging a little in the front from the extra weight.
I still would like to lift my C20, but I think I'm going to put it on the back burner for right now. Thanks again!
White70C20
2005 Pontiac G6
Old 08-29-2013, 05:49 PM   #16
Katrina/10
Katrina/10's Avatar
Re: Lifted 2wd?
Put a 3 or 4 inch body lift on it, no suspension mods req'd.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 08-29-2013, 06:50 PM   #17
71sierragrande
Petroleum User
71sierragrande's Avatar
Re: Lifted 2wd?
If you do a body lift, it shows the frame a lot more than at stock height, so make sure its lookin good
1971 GMC Sierra Grande 2WD 1/2 ton, 350/400 auto
2008 Chevy Silverado 2WD 1/2 ton LT1 5.3L auto
71sierragrande is offline   Reply With Quote
Old 08-30-2013, 11:43 PM   #18
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
Re: Lifted 2wd?
Just saw this thread and thought I would chime in. I'm with you on the lowered trucks (not for me). That's the beauty about these trucks... there are so many options. Check out my picture link below. When I did front disc conversion I changed out the front springs. I installed some HD springs (P/N 2772074) bought from NAPA. Tires do not rub at all. They are 285/70-17 tires with H2 Hummer wheels. The ride is a bit stiff, but hey it's a 3/4 ton truck. Here's a comparison of the springs:
The stock HD C20 springs are as follows:
http://www.napaonline.com/Catalog/Ca...752_0162319756
Part No.: 2771752
No. of Coils: 7.92
Free Height: 12.94"
Spring ID: 3.68"
Spring Load Height: 10"
Design Load: 2950
Spring Rate: 1016
Wire Diameter: 0.812"
The springs I put on from C10, C20, C30 from 1973-83. They are as follows:
http://www.napaonline.com/Catalog/Ca...074_0162301536
Part No.: 2772074
No. of Coils: 8
Free Height: 13.61"
Spring ID: 3.676"
Design Load: 3841
Spring Rate: 1060
Wire Diameter: 0.83"
You could also use C30 mid '80's 1-ton springs, but I thought they would be too stiff. Those are:
http://www.napaonline.com/Catalog/Ca...085_0162304063
Part No.: 2773085
No. of Coils: 7.93
Free Height: 13.34"
Spring ID: 3.65"
Spring Load Height: 11"
Design Load: 3289
Spring Rate: 1318
Wire Diameter: 0.906"
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 08-30-2013, 11:50 PM   #19
bruin_d
bruin_d's Avatar
Re: Lifted 2wd?
Go big or go home....
http://giantmotorsports.com/content/view/85/105/
bruin_d is offline   Reply With Quote
Old 11-21-2013, 03:58 PM   #20
Jahloha
Jahloha's Avatar
Re: Lifted 2wd?
Part No.: 2771752
No. of Coils: 7.92
Free Height: 12.94"
Spring ID: 3.68"
Design Load: 2950
Spring Rate: 1016
Part No.: 2772074
No. of Coils: 8
Free Height: 13.61"
Spring ID: 3.676"
Design Load: 3841
Spring Rate: 1060
Part No.: 2773085
No. of Coils: 7.93
Free Height: 13.34"
Spring ID: 3.65"
Design Load: 3289
Spring Rate: 1318
What conversion kit did you use? Was it pretty straight forward?
-JASON
My grandpa, Gramps, won a 1970 C20 in 1969 for $1. I'm on a mission to restore it before he passes.
My 1970 C20 Build Thread
Jahloha is offline   Reply With Quote
Old 11-22-2013, 10:27 AM   #21
derotoreut
derotoreut's Avatar
Re: Lifted 2wd?
I used Performance Online 8-lug conversion kit. It was straightforward and customer service was very good.
~ Dan
