Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current Classic GM Trucks Classifieds > Vendors Marketplace
Closed Thread
Old 10-09-2013, 12:20 PM   #1
tech@scottshotrods
Wilwood combo prop valve/brake switch with bracket
New for 2013, Wilwood is now offering it's classic proportioning valve as a combination item that houses not only the valve but also the brake pressure switch. This one piece unit eliminates the need for extra fittings and wiring.
The kit includes:
Proportioning valve
master cylinder bracket
brake light pressure switch
mounting hardware
hard lines to the master cylinder
We have these in stock, ready to ship. $110.00 shipped!
tech@scottshotrods is offline
Old 10-16-2013, 04:06 PM   #2
Scottshotrods
Re: Wilwood combo prop valve/brake switch with bracket
ttt
Scottshotrods is offline
Old 12-12-2013, 12:28 PM   #3
tech@scottshotrods
Down to only a couple of these left. These work great!
Old 03-03-2014, 12:48 PM   #4
Scottshotrods
ttt
Old 03-04-2014, 10:27 AM   #5
Scottshotrods
ttt
Old 06-30-2014, 02:37 PM   #6
Scottshotrods
We have a ton of these items in stock and they work great let us know and we will take care of you
Justin
Old 10-11-2014, 02:51 PM   #7
kitsbeach
kitsbeach's Avatar
How easy are these to hook up to a stock style master cylinder.? I'm about to do front drums to disks swap on my 67.
Are lines available for between the MC and the prop valve.?
and should I replace the front brake lines and do they hook up easy or need an adapter.?
Kitsbeach (Ken)
1967 C10 LWB (now SWB) Fleetside 6cyl Saginaw three-on-the-tree "No Frills"
1980 C20 Long to short & static drop "Square One"
kitsbeach is offline
Old 10-11-2014, 03:09 PM   #8
BMERDOC
BMERDOC's Avatar
In for the answer to the question. I'm doing the same thing.
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline
Old 10-13-2014, 11:31 AM   #9
harleyhouser
harleyhouser's Avatar
are these still available? If so what is to gain over stock?
harleyhouser is offline
Closed Thread
