Old 10-16-2013, 09:41 AM   #1
smoked68
smoked68's Avatar
68 swb C-10 Posi for rear?
Hi, Finally have the truck ready to paint and want to do one last thing to it. I need and want a posi unit for the stock 8.75 rear. What have you guys been putting in? And wheres the best place to get it? Detroit Locker? Eaton? Thanks, Mike
1968 chevy shortbed, Dark Shadow Gray
4 bolt 383 Stroker,Weiand Super Charger, disc brakes, 9 inch, 391 gear, 20" Eagle wheels, muncie 4 speed/ Hurst shifter, 4/7 drop, Hedman midlengths, 3 inch exhaust w/ 2 chamber flows. 1966 Mustang with 306 roller, c-4, 9 inch Detroit locker rear. 1965 Fastback Mustang w/347 stroker, top loader 4spd, 9 inch detroit locker. 1966 Mustang coup, 306 roller, c4, 9 inch. 65 Cobra, 427, T6oo, 9inch, of course. First gen Hayabusa, airbox mod and running 2 exhaust cams.. Zoom Zoom Zoom
smoked68 is offline   Reply With Quote
Old 10-16-2013, 05:16 PM   #2
bbcmudtruck
Re: 68 swb C-10 Posi for rear?
Any one of those companies you mentioned would be a good choice. The last lockers I used in a 4wd were detroits. I would like to try an Eaton unit the next time I have to put one in though. They are supposed to be quieter and work a little better on the street. You don't want to put a full locker in if your going to be on the street. You need a posi trac unit.
bbcmudtruck is offline   Reply With Quote
Old 10-16-2013, 05:22 PM   #3
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Eaton posi-traction unit. Best $400 bucks you'll ever spend on your truck.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 10-16-2013, 05:24 PM   #4
smoked68
smoked68's Avatar
thanks for input, and any possibility youd have parts numbers or where you got it. Im a ford guy figuring out a chevy. thanks, Mike
Old 10-16-2013, 06:05 PM   #5
bbcmudtruck
I'd be certain that summit has them. You'll need to know which carrier and gears you have.
Old 10-16-2013, 06:48 PM   #6
Lattimer
Lattimer's Avatar
http://www.summitracing.com/parts/et...make/chevrolet
Which one depends on which carrier you have.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
