Old 10-21-2013, 12:52 AM   #1
sduckworth13
sduckworth13's Avatar
Looking for Porterbuilt airbag plate install pics
I attempted to put my bag plates on the crossmember today and the holes in the bag plate doesn't center the bag on the crossmember pocket if I have the holes around the bag plate situated under the lip of the crossmember and bag bolted in either hole in the PB lower a arm. I could make a plate or I could just modify the plate to make it work but was hoping all I had to do was center my plate to where the holes would be directly under the crossmember lip and drill my four hole and be done. Would anyone have an pics with their Porterbuilt airbag plate bolted to the crossmember and a separate pic of the air bag installed. I'm using the airbag plates that came in the stage 1 front kit.
Thanks,
Scott
Scott
sduckworth13 is offline   Reply With Quote
Old 10-21-2013, 10:16 AM   #2
Pro Performance
Pro Performance's Avatar
Re: Looking for Porterbuilt airbag plate install pics
Hey Scott,
I do have pictures of the bag plates and PB arms on a stock cross member. I will dig them up and post them shortly. You won't need to modify the plate at all.
- Travis
Pro Performance is offline   Reply With Quote
Old 10-21-2013, 10:53 AM   #3
sduckworth13
Great!! Thank you Travis.
Scott
Old 10-21-2013, 11:04 AM   #4
Pro Performance
This is using the outer hole on the control arms.
Old 10-21-2013, 11:12 AM   #5
sduckworth13
Thank you Travis. Do you have any of the underside of the crossmember with the bag plates installed.
Scott
Old 10-21-2013, 11:15 AM   #6
Pro Performance
No problem. I will have to take some of the underside a little later today for you. That plate with have a notch in it, and that goes towards the rear.
Old 10-21-2013, 11:48 AM   #7
sduckworth13
Thanks Travis.
Scott
