10-23-2013, 12:12 PM | #1 |
Coil Springs - 1965 or 73-87?
Before I order parts I thought I had better ask...
So, I have 73-87 drop spindles that I am installing on my 1965 C-10 and I was wondering if I match the replacement coil springs to the control arms (65) or the spindle (73-87). I'm assuming that I need to match to the control arms as this is where the spring is housed, but I wanted to make sure... Thanks!
Travis' Tribute Truck - 65 C10 Frame Up Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=495073 |
10-24-2013, 01:29 AM | #2 |
Re: Coil Springs - 1965 or 73-87?
When I ordered my springs from ECE I ask the same question. 81 a-arms and a 66 crossmember. Short answer, they are the same springs.
Several different companies springs are listed as the same part number whether listed as a 65-66 or as an 85. The 65-66 is listed as a "C10 Pickup" where the 85 is simply listed as a C10. Many of the part numbers are the same.
Doug Old Build Thread - 383/T56 http://www.67-72chevytrucks.com/vboa...d.php?t=540838 Updated Build Thread - Modern Relic - 66 C10 536 Dark Aqua 5.3/4L60E - BTR Stage IV Truck Cam - Vintage Air - Dakota Digital http://67-72chevytrucks.com/vboard/s...d.php?t=778784 |
