Old 10-31-2013, 11:52 PM   #1
jks67ss396
reuse pitman and spindle nuts?
Hey guys
I wanted to know if its ok to reuse the castle nuts on the spindle (ill use new cotter pins obviously) and also if its ok to reuse the nut and lock washer on the pitman arm?
thanks!
jks67ss396 is offline   Reply With Quote
Old 11-01-2013, 06:22 AM   #2
bigmac73
bigmac73's Avatar
Re: reuse pitman and spindle nuts?
I dont see why not, as long as the threads are in good shape, but I have to ask did the new parts come with new ones???
Assuming you installed new parts??
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 11-01-2013, 09:48 AM   #3
jks67ss396
nah, the moog pitman arm didnt come with a new nut/washer and im reusing stock spindles...
thanks Mike!
Old 11-01-2013, 11:19 PM   #4
swamp rat
swamp rat's Avatar
Only nuts you don't reuse are the steel compression lock nuts and Nyloc brand lock nuts.
Castle nuts are fine as long as threads are good and no damage to the castle portion.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 11-02-2013, 02:05 PM   #5
WIDESIDE72
WIDESIDE72's Avatar
I hope its ok as i have been doing it for years! it is as a nut is not a wear item.
WIDESIDE72 is offline   Reply With Quote
