Old 11-14-2013, 08:17 PM   #1
Duck.E
Belt Help!!!!!!
I have an alternator belt that won't stop squealing. I changed belts and no difference, changed alternators and no difference and I even sanded the pulley grooves with a medium grit and no difference. I even aligned them the best I could and still yet again no difference. It only squeals at idle when I rev it hard or hit the gas hard on driving. Any input would be appreciated.
Duck.E is offline   Reply With Quote
Old 11-14-2013, 09:46 PM   #2
geezer#99
geezer#99's Avatar
Re: Belt Help!!!!!!
Find a belt that fits's deeper in the pulley. The one on the water pump looks to be sitting a bit high.
Old 11-14-2013, 10:44 PM   #3
Duck.E
Re: Belt Help!!!!!!
Both belts are almost flush with pulley itself and I don't have any problems with the belt that that goes from pump to crankshaft to power steering. Its the alternator for sure.
Old 11-15-2013, 02:40 AM   #4
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Belt Help!!!!!!
Have you made sure the vee-angle of the belt exactly matches the vee-angle of the pulley grooves? My only other thought is that in spite of your efforts, the pulleys might not be in perfect alignment. Can't tell by the pic, sorry.
Have you tried rubbing a bar of soap against the belt with the engine idling? It won't fix the problem but will often stop the squealing for a short time. Just one more way of proving that's the problem belt. Usual disclaimer about keeping clothing and fingers away from moving fans, belts, & pulleys....
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 11-15-2013, 03:26 AM   #5
Duck.E
Re: Belt Help!!!!!!
The angles match pretty close, may not be exact. At first it was way off but after shimming and moving got them close with straight edge. Ill give the soap a shot tomorrow. Other than that idk.
Old 11-15-2013, 09:39 AM   #6
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: Belt Help!!!!!!
When you look at v belts,check that the angles are the same in this area \V/ .There are differences in belts and the actual grip from a V belt comes from the area between the slash and the v.If those angles don't match,you will have very little grip area and squealing will occur.Belts should not have to be extremely tight to grip but should be snug.Debris in the bottom of the pulley,not allowing the v area to seat down into the groove well will also cause this.I see the belt is notched on the back side which is pretty common with industrial belts which have tons of variations.Belts should also be either flush or just under the top of the pulley foor full contact thru the v area. Just some inights I have learned over the years.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 11-15-2013, 12:41 PM   #7
luvbowties
luvbowties's Avatar
Smile Re: Belt Help!!!!!!
I'd think a slightly longer belt would allow alter to swing outward and downward, and give a bit more contact-distance on alter-pulley's diam. Also, use a well-known-for-quality belt. One good, usable belt that costs $18 is better to have than nine, cheap, $2-belts--same total cost--that aren't usable due to unlimited stretching and squealing. Remember to choose one that conforms to good, previous suggestions as well.
Sam
luvbowties is offline   Reply With Quote
Old 11-15-2013, 12:45 PM   #8
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Thumbs up Re: Belt Help!!!!!!
This is the point I was trying to make in my first sentence above.... I don't think he understood what I was getting at.
Thanks for explaining it much better than I did!
- Mike -
RIP El Jay
Old 11-15-2013, 12:50 PM   #9
Lee H
Lee H's Avatar
Re: Belt Help!!!!!!
The pulley may have the contact surface worn to the point where the belt will no longer have full contact with the pulley.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner.
1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components.
My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703
Lee H is offline   Reply With Quote
Old 11-15-2013, 05:44 PM   #10
Duck.E
Re: Belt Help!!!!!!
After looking at it closer the belt does sit too high, it's not flush at all and I can see where the belt is hitting in the groove and there is still untouched pulley deep in the groove. I have both the belt u see in the pic and a cogged one on the inside, but again, both sit too high. I'll have to get another one with a smaller V.
Old 11-16-2013, 12:43 PM   #11
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
Re: Belt Help!!!!!!
I have a serpentine set up, but had similar problem with belt squeal. Thought I had a good belt with Dayton. Chased the problem for a while. Finally someone told me to ditch the Dayton and go with a NAPA gold belt. Problem solved. I know it's not the same as yours, but just a thought. Good luck.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 11-16-2013, 04:51 PM   #12
Duck.E
Re: Belt Help!!!!!!
I have tried long and short belts, napa, gates, dayco, generic, loose and tight and no change at all. I'm about to throw in the towel. Only thing I can think of is a different setup, maybe go to a driverside mount instead of passenger.
Old 11-16-2013, 05:30 PM   #13
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Belt Help!!!!!!
But you said the belt doesn't fit the pulley. Good chance that's your problem. Are you not able to find one with the correct width and angle?
How does the belt fit the waterpump pulley? If it's good, you might have the right belt, but need a different pulley on the alternator.
- Mike -
RIP El Jay
Old 11-16-2013, 06:11 PM   #14
vidman
vidman's Avatar
Re: Belt Help!!!!!!
Whats The Number On The Belt ???
62 Willys 4wd Pickup : 72 C-10 swb 504 stroker 09 Taco 3" lift 33" tires: 90 K-5 blazer (plow truck): RIP Ross Little brother
vidman is offline   Reply With Quote
Old 11-16-2013, 06:53 PM   #15
Duck.E
Re: Belt Help!!!!!!
Belt fits the water pump fine, it just seems to stick up out of the alternator pulley to much, its not flush. I tried a smaller width same problem. My next step might be a different pulley, I read someone used a Z28 deep groove pulley and that solved their problem.
Old 11-16-2013, 06:54 PM   #16
Duck.E
Re: Belt Help!!!!!!
Gates XL 7315.
Old 11-16-2013, 09:01 PM   #17
geezer#99
geezer#99's Avatar
Re: Belt Help!!!!!!
Have you tried belt dressing?
You might need to go to a double belt pulley set up.
http://prestone.com/enca/node/437
Old 11-16-2013, 11:07 PM   #18
RichardJ
Re: Belt Help!!!!!!
You say it is the alternator belt slipping for sure. How do you know that? Is the alternator belt slipping on the alternator or on the water pump?
I'm not saying it's not, I just would like to know how you are making that determination.
The two grooves on the water pump pulley appear to be different diameters. Are the two grooves on the crank pulley also different diameters?
If the two grooves on the crank pulley are the same diameters, both belts will be traveling at the same speed. That means that at least one belt will be slipping on the water pump pulley at all times. One belt is on the tension side of the drive pulley, the other belt is on the take-up side of the drive pulley. That can have an effect on what you're hearing and when.
There are several things that may be in play here. Pulley diameter matchup and degrees of contact on the circumference of the pulleys.
Better pictures of all the pulley positions would be helpful.
'67 GMC 2500, 292, 4spd, AC
RichardJ is offline   Reply With Quote
Old 11-16-2013, 11:11 PM   #19
litew8
litew8's Avatar
Re: Belt Help!!!!!!
How tight did you put it on? You should pull it tight, then slightly let up so there is a small amount of sag on the either the top or bottom, then tighten your bolt.
project: "my happy mess"
litew8 is offline   Reply With Quote
Old 11-17-2013, 12:50 AM   #20
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Belt Help!!!!!!
I tried belt dressing and all it did was made a sticky mess. Never again. I emptied the can killing carpenter bees, so it wasn't a total loss.
- Mike -
RIP El Jay
Old 11-17-2013, 03:47 AM   #21
swamp rat
swamp rat's Avatar
Re: Belt Help!!!!!!
Take the belts off and fire up the truck and see if the squeal stops, then put 1 belt on and try again, then take that belt off and install the other belt..
One time i had a belt squeal that was driving me crazy trying to figure it out, it turned out that the manifold vacuum port for the tranny was left unplugged and the tranny vacuum tube was hooked to the carb, it was a vacuum leak that would whistle when the engine was revved, something to consider?
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Old 11-17-2013, 04:28 PM   #22
Duck.E
Re: Belt Help!!!!!!
I have not tried belt dressing yet and the belt is not super tight, I backed it off a little.
Old 11-17-2013, 04:36 PM   #23
Duck.E
Re: Belt Help!!!!!!
I haven't taken both belts off yet, but when I remove the belt from the water pump to alternator, there is no more squeal.
Old 11-17-2013, 04:51 PM   #24
Duck.E
Re: Belt Help!!!!!!
After looking at the water pump pulley the groove that the alternator belt is on is about 1/16 smaller then the other groove on the water pump pulley. I don't know that the belt is slipping on the alternator pulley for sure, it could be the water pump pulley. I just assumed it was the alternator pulley. As far as the crank pulley grooves go, they appear to be the same, but only one groove is being used on the crank pulley. To me it looks like the belt sits to high on the alternator pulley and isn't flush, but I put one on there that was and it still squealed. I tried to take a better pic of set up. See below.
Old 11-17-2013, 05:03 PM   #25
litew8
litew8's Avatar
Re: Belt Help!!!!!!
Loosen the belt as much as you can to see if/when it stops squealing, then gradually tighten up to where it starts squealing again. I'm guessing you know it isn't a bearing sound.
