Old 11-20-2013, 10:58 AM   #1
ksshane
ksshane's Avatar
BB... Will my 4sp be okay for now?
Ive been talking with one of our members and it sounds like we might be meeting up soon and me walking away with a BB he has.
My question is, I cant afford to buy a new transmission right now and pick up the BB. Will my original 4sp with the granny gear standard tranny bolt right up, and will it hold up to the engine until I can put something else behind it... Im guessing about 6 months.
71 swb 350/4sp manual 5/7 static drop
ksshane is offline   Reply With Quote
Old 11-20-2013, 11:18 AM   #2
OLDGREY
OLDGREY's Avatar
Re: BB... Will my 4sp be okay for now?
I think it will bolt directly to the BB. The tough part will be waiting to get something else behind it.
OLDGREY is offline   Reply With Quote
Old 11-20-2013, 11:58 AM   #3
Longhorn 70
Longhorn 70's Avatar
SM465s are tough. I have put 400+ HP to one with no problems. I'd be more worried about the clutch and u-joints.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 11-20-2013, 12:26 PM   #4
OLDGREY
OLDGREY's Avatar
The SM465 is tough as nails. I just built one for my Jimmy. If the existing clutch is in good shape you should be fine. The flywheel should bolt right up to the crank. The u-joints are relatively inexpensive and would be worth doing even for a short time. We know all to well how six months can turn into a year.
Old 11-20-2013, 12:29 PM   #5
ksshane
ksshane's Avatar
Yea, U joints are not a problem... I dont have a problem replacing the clutch either if I need to.
Thanks for the feedback everyone.
Old 11-20-2013, 04:48 PM   #6
mrolds88
Only other thing to worry about is balance. GM used 3 different balances. One for the 454, one for the 400 and one for the rest.
72 GMC C2500 402/Th400 first truck (still have)
77 GMC C3500 CC dually Sold
70 C50 dump truck "Rusty"
87 K10 Suburban Sold
93 K2500 xcab 6.5TD
96 GMC K2500 Suburban 6.5 TD
mrolds88 is offline   Reply With Quote
Old 11-20-2013, 05:11 PM   #7
uncle
Finding the right linkage parts can be a challenge too.
uncle is offline   Reply With Quote
Old 11-20-2013, 05:16 PM   #8
OLDGREY
OLDGREY's Avatar
I totally forgot about the linkage issue. Those parts do vary from one application to another. I've been hunting and pecking for some of the parts I needed to finish my swap. Very good point!
Old Grey-Grandpa's 1969 C-10 SWB in limbo.
1972 GMC Jimmy 4x4, soon to be a driver.
1972 C-10 Custom, daily driver.
Bad decisions make great stories!
Old 11-21-2013, 10:08 AM   #9
ksshane
ksshane's Avatar
Which linkage are you refering to?
Old 11-21-2013, 11:14 AM   #10
OLDGREY
OLDGREY's Avatar
I don't know if the Z-bar is the same for a BB as it is for a SB, or what the mounting position is for the ball stud that mounts on the engine side of the bar. I know there is a bracket that goes on a straight six but, not one on 350.
Old 11-21-2013, 11:20 AM   #11
hyatt
you will need bigblock flywheel Balance is not same on smallblock
1946 car hauler
1948 surburban
1937 chevy sedan
1940 olds sedan (project)
1967 ss396 chevelle
1999 dually crewcab(24000 miles)
hyatt is offline   Reply With Quote
Old 11-21-2013, 12:01 PM   #12
bbcmudtruck
Most sbc's are internally balanced. Depending on the size or build of your new motor will be either internal or external. The 454 is externally balanced unless its been built to be internally balanced. What motor did you end up getting? Also, I have a clutch rod still screwed into one of my blocks thats out in the shop if you need one.
bbcmudtruck is offline   Reply With Quote
Old 11-21-2013, 07:38 PM   #13
ksshane
ksshane's Avatar
I haven't got anything yet. Still working out the details
Old 11-22-2013, 08:01 PM   #14
ksshane
ksshane's Avatar
what about radiator... will the radiator I have work, or is there a way to tell. I know my radiator is not the stock radiator that came with the truck because my truck is a standard, but my radiator has the automatic transmission hookups with tubes cut off so I know it was pulled from something else
Old 11-22-2013, 08:30 PM   #15
67chevy1
67chevy1's Avatar
I don't know much about the clutch issue, but the radiator. I had a 454 in my 67 and the stock radiator it did fine unless when cruising on a weekend night in a lot of stop and go traffic more stop than go it would get hot but as normal in town driving or highway I didn't have a bit of troubles. And they are right a 454 is externally balanced.
67chevy1 is offline   Reply With Quote
Old 11-22-2013, 08:38 PM   #16
Hawghauler
Hawghauler's Avatar
I think the BB and Sb use a different bellhousing. The trans should work fine otherwise. As for the clutch linkage, I don't know.
If I have to be on 4 wheels, It has to be a classic Chevy
1967 c10 Longbed (Hawghauler/Icy weather transport)
2003 BMW K1200GT (Rain bike)
2007 Softail Deuce (Sun bike)
2009 Ultra Classic Electra Glide (Everything else bike)
Hawghauler is offline   Reply With Quote
Old 11-22-2013, 09:52 PM   #17
67_C-30
I have a radical idea!
67_C-30's Avatar
No, they used the same bellhousing from 250 L6's to big blocks.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 11-22-2013, 11:37 PM   #18
Hawghauler
Hawghauler's Avatar
Well I guess I stand corrected. You know it's surprising how many things you thought you knew, aren't....
