Old 12-03-2013, 02:41 AM   #1
ProjektDirtFab
ProjektDirtFab's Avatar
bagging with ram steelies
hey guys. i can come by some 20" ram steelies CHEAPPPP! and i know theyre 5.5 and our c10s are 5 and guys run the adapter plates..
my question is. anyone run the adapter plates and lay frame? even if i get the thinnest plates and go porterbuilt or thorbeck on the crossmember, after all the narrowing is done and the adapter plates kick the tire back out an inch or so.
anyone done this?
ProjektDirtFab is offline   Reply With Quote
Old 12-03-2013, 03:37 AM   #2
andrewmp6
Re: bagging with ram steelies
See if you can find out the back spacing of the rims and how thick the spacers are,And last i heard thorbeck wasn't making their raised crossmembers the guy making them quit and left with the blue prints.
andrewmp6 is offline   Reply With Quote
Old 12-04-2013, 12:45 AM   #3
Ziegelsteinfaust
Is it possible to re-drill the hubs for the 5x5.5?
Ziegelsteinfaust is offline   Reply With Quote
Old 12-07-2013, 01:24 AM   #4
evan_cartech
evan_cartech's Avatar
cpp drop spindles pull tires in I think an inch overall but are only 2" drop but would fix your issue and if u using drop member should not b a problem
evan_cartech is offline   Reply With Quote
Old 12-07-2013, 01:33 AM   #5
ProjektDirtFab
actually were going MII front end which will give us 60" track so with 5x5.5 adapters @ 1" wide per side. depending on the offset of the rims. the tires should be an inch or 2 narrower from stock letting us tuck even better and maybe get a little turning while laid out....only time will tell haha
Old 12-07-2013, 09:33 AM   #6
pete63
Active Member
Offset is 19mm makes backspace about 5.25. I did find some 20 mm adapters (about 3/4") was the thinnest ones I could find at time.
pete63 is offline   Reply With Quote
Old 12-07-2013, 01:08 PM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
Sometimes "cheap" is not worth the price. If it were me I would use the money your going to spend to get these cheap wheels to fit on a set of wheels that actually fit.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 12-08-2013, 09:04 PM   #8
ProjektDirtFab
well these are the wheels i need to get the look i want. and now that i think about it i would probably need to use wheel adapters or something to take up a couple inches being that the MII track width is only 60"...stock 77 c10 is 65" and some change. so after all is done and said it would probably be real close to stock width. unless you know of a place that has 20" black steelies that arent $200+ a piece?
looks pretty good to me!
Old 12-12-2013, 11:02 AM   #9
N2TRUX
Happy to be here
N2TRUX's Avatar
If you know what your getting in to, then go with your plan. I wanted to point out that the cost of quality billet adapters was going to put you close to the cost of a direct fit wheel. If your after a certain look, go with it.
Articles-
"Refining Sierra"
