Old 12-14-2013, 01:11 AM   #1
mike14_07
mike14_07's Avatar
Cowl leaks
Im getting some water inside my cab, one starts under the dash, drivers side around the support for the inner fenders and the other is the drivers side fresh air vent leaks around it. i checked for debris, it was clean, is there a seam in that area? if not im guessing windshield? how can water leak around the fresh air vent, the "lungs" are clean
mike14_07 is offline   Reply With Quote
Old 12-14-2013, 08:15 AM   #2
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Re: Cowl leaks
My suburban does the same thing. It is rotted under the dash right where the fresh air boxes are spotted to the upper cowl.
I plan on drilling out spots, and removing them for repair.
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 12-14-2013, 09:43 AM   #3
Snailed
Snailed's Avatar
Re: Cowl leaks
Mine leaks from the spot welded seam in the bottom of the cowl, in front of the glovebox. I assume there was some seam sealer between the two panels originally. This picture I stole shows the seam.
Daily Driver '66 C10 Fleetside Short Bed - LS swap - 4L80E - Accuair eLevel
Snailed is offline   Reply With Quote
Old 12-14-2013, 01:00 PM   #4
mike14_07
mike14_07's Avatar
Re: Cowl leaks
looks like i need to remove the lung to repair?
Old 12-14-2013, 05:15 PM   #5
Rich 5150 69
Rich 5150 69's Avatar
Re: Cowl leaks
Mike... note that the rain gutter above the windshield if it leaks, it will run to the windshield post and down either to the side panel or agaisnt the inside of the firewall. I had that issue.
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 12-14-2013, 10:58 PM   #6
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Re: Cowl leaks
Fixed mine
http://67-72chevytrucks.com/vboard/s...23#post6038323
66 C20 Service Truck:
Old 12-15-2013, 04:05 AM   #7
JPBrecheisen
Re: Cowl leaks
The one under the dash might be coming from where the wiper motor mounts to the inside of the cab.
The seal on mine isn't the best and I get a few drops inside in a heavy rain. I haven't looked into it full scale yet, but after a brief look, I think that's the culprit in my case. That might be the case for your under dash leak.
Jonathon
1960 GMC K1500 LB Fleet Side
1962 GMC K1000 LB Step Side
1988 Chevrolet C2500
JPBrecheisen is offline   Reply With Quote
