01-06-2014, 02:08 PM | #1 |
Rear Hatch shocks
I have a double wall top and I need shocks for the hatch. The ones I have on right now are not the original and they never had the force to hold the hatch. Does anyone know where I can get some shocks and what Brand/model/part #? Thanks in advance.
01-06-2014, 02:21 PM | #2 |
Re: Rear Hatch shocks
Fairly certain they aren't reproduced. They arent conventional shocks and I cant think of the correct term but they hold the hatch up and latch to hold the hatch up. To lower, you raise the hatch a hair so they disengage then lower it. I may have and extra set.
01-06-2014, 06:30 PM | #3 |
If they're gas pistons, they're not original. The originals were latching mechanical supports.
01-07-2014, 04:17 PM | #4 |
thanks for the help I think I'll try and find gas struts though
01-09-2014, 01:02 AM | #5 |
Hi Timm,
If you do a search for rear hatch hinges or struts you should come across a fellow who found a set for both the heavy Sub door and he found some gas struts that had 1/2 the force that worked for the hatch as well but they came out of or fit a European car.. maybe Volvo or Saab.... it's a few years old but I am sure I saw some part#'s listed... - A.J.
******************************************** In-work on my 5.3L/4L65E/NP208 case conversion into a 1972 GMC JImmy 4x4... Not as simple as it looks folks.. |
