01-25-2014, 03:55 PM | #1 |
65 V8 long water pump, FAN SHROUD ideas?
A stock one won't fit and I don't want to cut up the perfect oe one that I purchased to make it fit. An aftermarket plastic one won't work and if cut down will have too large of fan opening by the time it fits ( 4" from rad to center blade)
Anyone run into this? Solution? My thoughts are fab up a nice sheet metal shroud or ditch all of the LWP stuff from the front of the engine and go with Short Water Pump stuff. Hoping someone says " oh yeah, just get a shroud from a ______and trim it
GOD BLESS AMERICA! |
01-26-2014, 02:47 AM | #2 |
60-66 Nut
Re: 65 V8 long water pump, FAN SHROUD ideas?
That's why I typically stick with short water pumps on the vehicles that originally came with them. Is your engine in the original location? I have seen other members run the long pump with a stock fan shroud, but when I tried it once, it didn't work. Not sure what the difference was.
01-27-2014, 10:00 PM | #3 |
post 33 stock fan shroud long water pump with a clutch fan
http://67-72chevytrucks.com/vboard/s...=502124&page=2
James 63 GMC V6 4speed carryall 65 chevy swb bbw V8 auto 68 K20 327/4 speed, buddy buckets 2002 GMC CC Dually Duramax 64 GMC lwb 3/4 V6 4speed SOLD 66 GMC swb bbw buddy buckets SOLD IG duallyjams The only thing that stays the same is constant change! |
01-27-2014, 11:16 PM | #4 |
^^^^^^ NICE! Now how good are you at shoving small cameras into tight spaces and getting a few pics? I would love to see which fan and clutch they are. My fan is flat and bolts to the backside of a fairly small clutch. Does the end of the taper area of the shroud land about half way through the fan blade if you dropped a plumb bob?
Thanks James!
01-28-2014, 10:21 AM | #5 |
I doubt you want to go electric fan but if you do I used a Lincoln Mark VIII fan. I had to trim a little off the top of the shroud to clear the radiator tanks and the radiator hoses and fab up brackets t mount it but I think it looks like it belongs there. While I was at it I installed a Radiator Overflow/Windshield Washer combo off a Ford Exploder.
01-28-2014, 01:37 PM | #6 |
ck out a chevelle big block 66/67 shroud. they are a little wider and bolt on flat but real short. can take a pic and measure if you want.
1961 chevy K10 my build is------------61K10 build |
01-28-2014, 04:41 PM | #7 | |
Thanks!
01-28-2014, 04:43 PM | #8 | |
01-28-2014, 06:24 PM | #9 | |
here's one pic I have from before
01-28-2014, 09:05 PM | #10 | |
01-28-2014, 10:48 PM | #11 |
The fan is off of a GM truck, I got it from board member teeitup he deals in 67-72.
01-28-2014, 11:32 PM | #12 |
Newfisher, do you realy need the thermostatic fan, if you just bolted on a 5 blade stock fan it would put it right where uou need it..?
`64 C10 vortec 350/350/373 posi `69 RS/SS 350/350/308 `37 Ford 406/350/324 traclock `68 Dart 370/904/323 suregrip |
01-29-2014, 01:21 AM | #13 |
I have had an aftermarket one mounted without the clutch and bought a few stock choices to play around with. Do I need one? Probobly not ,but its the little projects now that the truck is pretty much done, that keep me from buying another truck! I'm looking to change the MPG's on this thing with a fan clutch, some rear gears that work with the 700r4 and the 235/75/15s and either use my Holley projection or a quadrajet etc to maximize the economy side. In the end I will have spent more time and money farting with the little projects than it would take to drop an LS engine in it and at that point this thread is mute with the electric fan set up it keeps me off the couch and not wasting cash on 401k plans or house remodels lol
01-29-2014, 01:23 AM | #14 |
I have found that a 86 suburban 350 fan and an aftermarket fan clutch with NO shroud runs cooler indicated on the gauge than an aftermarket fan bolted direct drive to the pump without a shroud.
01-29-2014, 02:04 PM | #15 |
here is some pic's of the BB shroud--could be modded to work i think
27 1/2 wide 16 3/4 high 2 1/2 thick 19 1/4 fan opening
01-29-2014, 02:08 PM | #16 |
Thanks, I will measure mine tonight!
01-30-2014, 02:35 PM | #17 |
The fan shroud is a repo ( bowtie bits ) 70-72 7 blade clutch fan from board member Teeitup
01-30-2014, 02:38 PM | #18 |
plumb bob, hope these help, if you need more just let me know
01-30-2014, 06:08 PM | #19 |
Not factory looking but I've run an aftermarket chrome one for the past 15 years or so like this https://www.google.com/search?q=chro...90825447058319
01-30-2014, 07:44 PM | #20 | |
01-30-2014, 09:33 PM | #21 | |
