Old 02-02-2014, 09:23 PM   #1
Rentacop
Engine question
My 69 gmc has a 1973 Chevelle 350 small block with heads, intake and exhaust if the 69 350 anyone know if there was a purpose to this? It's confusing to me that someone would spend the time to use all their 69 components on a 1973 unless there was a hp or torque reason
Rentacop is offline   Reply With Quote
Old 02-02-2014, 10:13 PM   #2
Rod Run
Rod Run's Avatar
Re: Engine question
I'm sure that's probably just what they had on hand. That's what is done 99% of the time, when it comes to hot rodding
______________________
www.northeastrodrun.com
Rod Run is offline   Reply With Quote
Old 02-03-2014, 12:22 AM   #3
kray59
kray59's Avatar
Cool Re: Engine question
x 2 with what was on hand . that's the way folks with limited funds stay on the road as inexpensively as possible .
This is MY rifle.There are many others like it but this one is MINE.
Beware the man who only owns 1 rifle , he probably knows how to use it.
kray59 is offline   Reply With Quote
Old 02-03-2014, 01:29 AM   #4
Evan's 1965
Evan's 1965's Avatar
Re: Engine question
They prob figured the '69 pre smog heads & intake were better flowing than the 73 smog heads.
Evan's 1965 is offline   Reply With Quote
Old 02-03-2014, 02:25 AM   #5
1968k10blue
1968k10blue's Avatar
Re: Engine question
Or, the original engine had a bad/cracked or something block and they found a cheap block out of the chevelle to put in and bolt on all the other parts
Austin
2005 GMC Sierra 1500 4X4 4.8l V8 (Wrecked)
2003 Chevy 1500 standard cab short bed 4x4 w/ 5.3l
1968k10blue is offline   Reply With Quote
Old 02-03-2014, 08:00 AM   #6
Keith Seymore
Keith Seymore's Avatar
Re: Engine question
A lot of times it's easier to keep all the peripherals so that you know they will fit your chassis (ie, accessory drive bracketry, water pump and cylinder heads for attachments, etc).
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 02-03-2014, 08:14 AM   #7
Daman
Re: Engine question
What all these guys said.
If you find an all original small block engine in anything that has fitment from '55 to the '90s. Then you hit a small goldmine HAHA
Daman is offline   Reply With Quote
Old 02-03-2014, 01:57 PM   #8
geezer#99
geezer#99's Avatar
Re: Engine question
What are the date codes on the heads and block?
