Old 03-13-2014, 10:02 PM   #1
KellerMAC
KellerMAC's Avatar
Drivers Door Upper Hinge
Have some slop in my driver door hinge - I replaced the pins and bushings and the slop is still there - it appears that the bore of the pin hole to be enlarged due the original pin movement. My question is am I better off buying a new hinge or drill out the out of round hole and fabricate new bushings that fit?
If you think that I need to buy a new hinge, can you tell me where I can get one that is exactly what was put on at the factory and of good quality?
KellerMac
Texas - Don't Let The Size Scare You!
KellerMAC is offline   Reply With Quote
Old 03-14-2014, 09:19 AM   #2
burnin oil
Re: Drivers Door Upper Hinge
You should be able to go to the part store and get a different hinge pin and bushing kit that is larger diameter. When I rebuilt my hinges I needed to ream the holes slightly larger for the bushings to fit.
burnin oil is offline   Reply With Quote
Old 03-14-2014, 10:18 PM   #3
Lanman1972
Lanman1972's Avatar
I ordered a pair of upper hinges from Truck and Car Shop, fit great, easy install, and decent delivery time.
Lanman1972 is offline   Reply With Quote
