03-24-2014, 03:56 PM | #1 |
Wood or Steel
I need to replace the bed floor on my '67 C-10. I am torn between wood and steel.
Is there a benefit to one over the other? I figure steel will be easier to install and will last longer, but what are the weight differences? Wood i think looks more "classic" but most likely i will be throwing a tonneau over the bed anyway. So, what do you guys think? |
03-24-2014, 04:11 PM | #2 |
Carpe manana
Re: Wood or Steel
It's interesting that GM painted wood beds together with the sheetmetal...clear/stained wood finish is the rule today and looks great but not OEM
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 Members met: ORANGBLAZ, 2003 silverado, MikeCofield, BB72CHEVKT, Duncan&Son, Sameyrasmea72, THENEWMEXICAN, HotRod C/10, brianthelion02, Sport/Truck, ryanroo, michael bustamante, Dirt's72, Already Gone, WestButteTruck, 57taskforce, Moreyel, painterljp, AASmedic, SoCoC10, Lumaestas, carbuff382, Chevyland |
03-24-2014, 04:37 PM | #3 |
Re: Wood or Steel
Is it wood or steel now?
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
03-24-2014, 05:25 PM | #4 |
Re: Wood or Steel
technically it is wood.. But majority of it is missing because i ripped it out so i could install my new gas tank easier. It was falling apart anyway and needed to be replaced.
03-24-2014, 05:37 PM | #5 |
Re: Wood or Steel
I'd stick with wood. I believe I've read on here that the connections for the wood floor are different than steel so there would be more to change from one to the other than just buying the floor material. Someone else will need to confirm or correct the above statement though.
-Duane C/10 Club Texas member 1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project) 1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby) |
03-24-2014, 05:51 PM | #6 |
Carpe manana
Re: Wood or Steel
Header panels differ wood vs. steel - prob better to redo the wood bed.
03-24-2014, 05:52 PM | #7 |
Re: Wood or Steel
the front header panel is different. I like wood better myself, I'd go back with wood even if you just painted it like they did at the factory.
03-24-2014, 06:28 PM | #8 |
Re: Wood or Steel
The front panel and all the crossmembers are different between wood and steel. The wood floor option E81 is listed adding ~15 lb over the stock steel.
If you have wood you might as well keep it. But I do not advocate full blown "furniture" wood and finish either. Good quality yellow pine well sealed then installed and overpainted is a known durable bed. However I think using stainless hardware and strips is a good idea too and plan to do mine that way right under the paint. Here is a picture of a factory wood bed service replacement floor. The black is the soaked sealer they used prior to assembly. Then of course it was overpainted after bed assembly. Black in 67-68 then body color after that.
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
03-25-2014, 10:37 AM | #9 |
Re: Wood or Steel
Thanks for all the info. Sounds like wood is the way to go.
03-25-2014, 01:40 PM | #10 |
Re: Wood or Steel
Here's another option. Mine's a daily driver and this Texas sun/humidity eats wood. Wood is beautiful but this stuff (Trex decking)wears like iron and still has the look.
Figure out what you want--then figure out what you are willing to give up to get it. |
03-25-2014, 03:06 PM | #11 |
Re: Wood or Steel
I say wood for being practical that it's already set up for it, and, it gives it more character IMO.
Shawn 68 chevy K/20 05 chevy 3/4 4x4 71 short step-sold 71 chevy Beauville van My build. http://67-72chevytrucks.com/vboard/s...d.php?t=633039 |
03-25-2014, 03:11 PM | #12 |
Carpe manana
Re: Wood or Steel
On a tangent but I wonder: is the 72 pickup the final example of real wood used in the manufacture of a GM vehicle (or other US vehicle)?
03-25-2014, 03:16 PM | #13 |
Re: Wood or Steel
^^ could be wrong, but I was thinking stepsides through the late 70's still had it. SS Tim?
03-25-2014, 03:21 PM | #14 |
Re: Wood or Steel
I see they sell kits through 87.. Don't know about other breeds.
03-25-2014, 03:45 PM | #15 |
Re: Wood or Steel
If you are going to go to all the trouble to replace the wood, why not take the time to make it look extra sharp? $126 for Northern Red Oak, $40 for a gallon Spar Marine Varnish and about 8 hours of planing, trimming, sanding and finishing.
Just my 2¢. POP
2016 RAM Laramie HEMI 1966 Fairlane GT/A, 390/335 HP If it costs you a dollar to make a friend, KEEP THE DOLLAR. If it costs you a friend to make a dollar, KEEP THE FRIEND. |
03-25-2014, 03:50 PM | #16 | |
Re: Wood or Steel
id go with wood it gives character for an older truck. that treck decking fake wood stuff is a pretty sweet idea
1969 Shortbed in progress 1982 short step, few suspension and motor upgrades.getting a 468 1978 Shortbed fleet side bonanza fully loaded 1978 k20 Silverado loaded.currently engine-less 1989 k10 suburban 9" lift 65 nova And more |
03-25-2014, 03:51 PM | #17 |
Carpe manana
Re: Wood or Steel
Good info on history of wood beds - thanks. Pete
03-25-2014, 04:43 PM | #18 | |
Re: Wood or Steel
The RPO E81 option remained available for 8' fleetside beds up to 1980. Dad's '77 GMC was factory equipped with this option --> http://67-72chevytrucks.com/vboard/s...d.php?t=376467 |
03-25-2014, 04:53 PM | #19 | |
Carpe manana
Re: Wood or Steel
03-25-2014, 08:08 PM | #20 |
Re: Wood or Steel
03-25-2014, 08:22 PM | #21 |
Re: Wood or Steel
Wood beds were used back in the day for livestock/farmers. Softer on the animal's hooves.
project: "my happy mess" |
03-25-2014, 08:40 PM | #22 |
Carpe manana
Re: Wood or Steel
Sounds like a snowboard!
03-25-2014, 11:28 PM | #23 |
Re: Wood or Steel
Mar-k did a side by side on wood beds and used many different finishes. The one that with stood the test of time was: POR 15 then painted with oil base gloss black. All the other natural finishes did not hold up at all.
http://www.mar-k.com/wood_finish_testing_ii.aspx
JB from AZ 1969 Chevy Sub K10 1957 Chevy 3200 1962 VW Beetle 1957 Willys CJ5 |
03-25-2014, 11:33 PM | #24 |
Re: Wood or Steel
I'll pitch in on the wood side. And, although I can understand the itch to stain and clear it (it IS very good looking), for some weird reason I like to do it like the General did it himself - body color paint for this era of trucks. Both my 71 and 72 had the wood bed option (and medium olive wood is not something I would have said I "liked" 10 years ago, but...) and my 66 had the standard wood bed (but they were painted lamp post black thru 66, I believe - body color after that).
