Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > 47 - Current classic GM Trucks > The 1960 - 1966 Chevrolet & GMC Pickups Message Board > 60-66 Suburbans
Old 04-02-2014, 07:43 PM   #1
65chevysub
65chevysub's Avatar
3" lowering of rear of '65 Suburban
Does anyone have pictures of lowering blocks for a 65 Suburban? I want to lower just the rear end 3", and want to use blocks. Any thoughts on this? Everywhere I check online, there are lowering springs, but they say use only for pickups, not for Subs and Panels. If I go with blocks, how reliable are they, and how do they install?
65chevysub is offline   Reply With Quote
Old 04-03-2014, 01:29 AM   #2
RockTonka
RockTonka's Avatar
Re: 3" lowering of rear of '65 Suburban
Lowering springs for trucks work the same on burbs/panels...maybe a bit more drop because of the extra weight. I tried a set of rear drop springs on ours but didn't like the stance, also hit the bump stops with me on the bumper...knew that wasn't going to work for us.
We did make a couple 1 1/2" drop blocks to bring the rear of ours down a bit...very straight forward to install.
I don't think I've seen 3"drop blocks though
1958 Chevy 1 ton dually 4X4 dump/flat bed
My build thread
1966 "Not-So-Original" Chevy Custom Trim Suburban
My Time-Killing Project Truck
1966 GMC Extended cab 1 1/4 ton 4X4
My Son's build thread
RockTonka is offline   Reply With Quote
Old 04-03-2014, 09:13 PM   #3
Grandpa54
Grandpa54's Avatar
Originally Posted by rocktonka View Post
lowering springs for trucks work the same on burbs/panels...maybe a bit more drop because of the extra weight. I tried a set of rear drop springs on ours but didn't like the stance, also hit the bump stops with me on the bumper...knew that wasn't going to work for us.
I don't think i've seen 3"drop blocks though
what kinda of stabilizer bar is on your truck do you have more pics, thanks mark
Grandpa54 is offline   Reply With Quote
Old 04-04-2014, 02:27 AM   #4
RockTonka
RockTonka's Avatar
I used the rear sway bar and brackets off of a 84 Z28 Camaro. For me, it fit best upside down and backwards. The pics below are from when I first adapted it to the stock 12B...the pics above are on the current narrowed D60...same layout though.
My build thread
Old 04-04-2014, 03:24 PM   #5
Grandpa54
Grandpa54's Avatar
i used the rear sway bar and brackets off of a 84 z28 camaro. For me, it fit best upside down and backwards. The pics below are from when i first adapted it to the stock 12b...the pics above are on the current narrowed d60...same layout though.
looks great, im keeping mine stock height do you think it will work for me?, thanks mark
Old 04-05-2014, 12:33 AM   #6
RockTonka
RockTonka's Avatar
Yes, it will work with a stock height suspension...that's how it was originally set-up with the 12B.
My build thread
Old 04-15-2014, 11:07 PM   #7
Grandpa54
Grandpa54's Avatar
Do you remember who you got the sway bar from?
Old 04-16-2014, 12:22 PM   #8
RockTonka
RockTonka's Avatar
Pull-a-part
My build thread
