Old 04-04-2014, 12:11 AM   #1
solidaxel
solidaxel's Avatar
MAF Intake
What is the closest distance you can mount the MAF to the throttle body and still work properly
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
Old 04-04-2014, 12:26 AM   #2
dman1982
dman1982's Avatar
Re: MAF Intake
good question...
Sgt Dennis Heineman
USMC Aviation Ordnance
I.Y.A.O.Y.A.S
2001-Present
84 K10
2000 trans am ws6
2011 nissan altima
2009 Troy Built with a 42 Inch Deck
My LS Swap http://67-72chevytrucks.com/vboard/s...=1#post6559371
dman1982 is offline   Reply With Quote
Old 04-04-2014, 01:10 AM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: MAF Intake
GM wants 10", I've about seen 5-6" work in a pinch, but that was on a straight section of tube off the front of the tb. The maf wants smooth air, so it wants to be on a straight shot of pipe, far enough from the tb that it won't get turbulence.
Can it be done with less, yes, but you sacrifice some accuracy to do so. On a stockish swap that "just has to fit", then its not a problem...but something being modded, tuned to max effort etc will suffer from it. If you have a tight clearance problem, and are still looking for power, you can consider running SD and eliminating the MAF
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 04-04-2014, 02:02 AM   #4
Andy4639
Old member
Andy4639's Avatar
Wink Re: MAF Intake
My 6.0 install. It runs just fine, is it a full all out performance machine no. Can I tell that it doesn't run to it's fullest... no! But BR3W CITY is correct in what he said though for a all out get every bit of performance out of it you can. Then no it's not the best way to set it up.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 04-04-2014, 08:45 AM   #5
solidaxel
solidaxel's Avatar
Re: MAF Intake
I have another build going on and we have vertical space, and the B H Custom air box would work, BUT I do not think the MAF will work, still looking!
LS 3 4L70E
Old 04-04-2014, 08:52 AM   #6
Jmiller022
Jmiller022's Avatar
Re: MAF Intake
Go speed density with your tune and do away with the MAF
68' c10 stepper 5.3/4L60e
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=578917
Jmiller022 is offline   Reply With Quote
Old 04-04-2014, 09:01 PM   #7
Iceburgh
Iceburgh's Avatar
Re: MAF Intake
explain speed density ...I have no clue hat that is?
Iceburgh is offline   Reply With Quote
Old 04-05-2014, 01:04 AM   #8
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Re: MAF Intake
The MAF uses the data from its vain and the IAT (included in maf) to gather an input figure, and it uses that data to help populate VE tables that the engine uses (for lack of a better word, the tune) to make power.
The thing is, you can use physics to mathematically achieve the same results. Something something something inert gas law something something something thermodynamics something something somethings horsepower. Essentially, to remove the MAF you can seperate the IAT and run a MAP sensor. This data plugged into an equation, along with engine RPM calculates the theoretical amount of air entering the engine at any given time. Technically speaking, there is greater "resolution" to this because the PCM isn't constantly fudging back and forth trying to achieve peak efficiency.
SD tunes give the max hp for any given condition, with the caveat being that the tune is way more "Static" than a MAF tune. Because a MAF reacts to changes in air volume, it can make changes to compensate for vast changes in weather, air density etc. SD tunes cannot do this in the same way, so a car SD tuned in Gainsville FL in summer will suffer power loss if raced in fall in Dorchester MD. Above about 750hp, the GM MAF loses its ability to accurately measure air volume and a specialty unit or an SD tune must be considered.
Help any?
Old 04-07-2014, 12:45 AM   #9
Root2812
Root2812's Avatar
Re: MAF Intake
This is really interesting. I's going to swap a 5.3 and will have clearance issues. My project isn't about power but more about cruising. Would this SD tune be something that I could do and not see a noticeable power loss in casual driving? I might romp on it once and a while but I don't plan to go racing. Really its just going to be for car shows and to take my family to get ice cream on summer days.
My other plan is to go with one of those S&P Maf/air cleaner combos that mount right on the throttle body. Of course that would keep the Maf much closer than 10 inches. Anyone have any comments on these units?
My 1950 Chevy build
Root2812 is offline   Reply With Quote
Old 04-07-2014, 09:44 AM   #10
Jmiller022
Jmiller022's Avatar
Re: MAF Intake
http://www.pcmforless.com/index.php?...ning&Itemid=56
speed density vs MAF
Old 04-07-2014, 10:06 AM   #11
GCncsuHD
Charlie Daniels w/ a Tq Wrench
GCncsuHD's Avatar
Re: MAF Intake
This is pretty much it. The main key is to reduce the turbulence so that the MAF can get a good reading, preferably in a straight shot of intake tubing. This is much more important if you have a "screenless" MAF. If you have a stock style with the honeycomb screen LEAVE THE SCREEN IN, it straightens the airflow for a better reading. Those are the ones that can usually work decently the way Andy has his, though not optimal, it will usually be OK that way. The ones without a screen will typically be all over the place if mounted like Andy's, but are usually fine if mounted in an ideal straight piece of intake tubing.
Speed Density is always an option, especially if space is an issue, or a cleaner look is desired (or for more precise tuning flexibility on forced induction or high HP builds), though for a daily driver with a mild build, especially one you like to take road trips in I would stick with MAF as the SD is sensitive to weather and elevation changes.
ΜΟΛΩΝ ΛΑΒΕ
67 C10 Shortbed "Great Grandpa's Truck" I6 3 on the Tree 71k original miles 5.3 swap in the works
69 K5 Blazer-Family Beach Cruiser Project
78 K30 Dually Semi-Retired Fire Truck 350/SM465 35"s
SOLD01 2500HD ECSB 6.0 4x4 5.13's 8" lift 38"s
GCncsuHD is offline   Reply With Quote
Old 04-07-2014, 11:12 AM   #12
Daaaanz67
Re: MAF Intake
How about this and change to SD.
Daaaanz67 is offline   Reply With Quote
Old 04-07-2014, 11:20 AM   #13
Daaaanz67
Re: MAF Intake
When I build my 56 thinking of this route and having ls performance and old school look.
Old 02-07-2015, 02:13 PM   #14
solidaxel
solidaxel's Avatar
Re: MAF Intake
Andy,
Are you still running your MAF next to the intake or did you move it to the center of the tube?
LS 3 4L70E
Old 02-08-2015, 09:28 PM   #15
Andy4639
Old member
Andy4639's Avatar
Thumbs up Re: MAF Intake
Still there. Hasn't seem to hurt it. The motor is all stock and runs good for me. I don't race it I don't even spin the tires on it. You can see in the picture that the tube isn't straight at all. I guess at some point I should try and figure out some other way but for now it seems fine.
