04-20-2014, 03:50 PM | #1 |
Clutch Linkage for a Big Block
Im wanting to know if the factory clutch linkage will work on a big block with headers. Im going to be swaping out my th400 and putting a tremec tko 5 speed and was wondering if the factory clutch linkage will work with headers or will I need to put a hydraulic clutch on it. I would prefer to use the clutch linkage if it wont interfere with anything.
04-20-2014, 04:16 PM | #2 |
Re: Clutch Linkage for a Big Block
My guess is that you are going to have problems.
Since you used chevelle headers it was not a consideration durng their manufacture. http://67-72chevytrucks.com/vboard/s...0&postcount=19 At this point your best bet would be to get some parts and see if they fit. As you won't be using the rear engine crossmember and bellhousing mounts there may be a little wiggle room to make it work. Also is your engine in a stock location with the aftermarket stands or is that another issue to deal with too?
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
04-20-2014, 04:34 PM | #3 |
I have a chevelle with a big block and headers. I don't understand how it wasn't a consideration. I believe I had to order them with exactly that consideration. The clutch linkage indexes off the same boss regardless or chevelle or truck, doesn't it?
I know a guy who's addicted to brake fluid. He says he can stop any time. 72 K10 396 75 Cj5 MPI 350 Chev 67 Chevelle 396, 4 speed 74 FXE 08 Tahoe |
04-20-2014, 04:38 PM | #4 | |
04-20-2014, 04:53 PM | #5 | |
Trucks keep the z bar a very specific location and use adapter plates to move the pivot ball location with some engine applications. IIRC the L6 and KE(V8) are the only direct to the block boss pivot balls. When it comes down to it, he has non-truck specific headers and aftermarket mounts with an engine placed in a non-stock location. So he is probably going to have to modify or mix and match to make it work.
04-20-2014, 05:03 PM | #6 | |
Jeff
04-20-2014, 05:10 PM | #7 | |
Jeff
04-20-2014, 05:48 PM | #8 |
Ill figure it out one way or another but if someone out there has any recommendations Im all ears. I guess as of now I just need to get my hands on some factory linkage sets and see if I can piece it together and go from there and if I have to chop, bend, or weld something it isn't going to be the end of the world for me as long as it works.
04-20-2014, 05:51 PM | #9 | |
04-20-2014, 09:32 PM | #10 |
i have nova/camaro headers installed on my 67 w a 454 they are close too a chevelle header if not the same. of course each differant brand of header is gonna be a lil' differnt.
i screwed the pivot ball into the block and relocated the mount on the frame. uesing all factory clutch linkages i had too cut the top ear off of my z bar and made a slightly longer ear and rewelded it at a differnt angle and location on the z bar. but i didnt touch the bottom ear. i had everything mocked up and it seemed too work ok but up untill i get the thing running and driveing i cant be 100% sure everything will be a-ok. one differance is my bb is mounted in the factory front holes with oe style mounts. but i am useing a trans mounted crossmember. idk how this will help you but i figured i say what i'd done
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. Last edited by midniteblues; 04-20-2014 at 09:40 PM. |
04-20-2014, 10:11 PM | #11 |
original clutch linkage for a big block is super rare.
04-20-2014, 10:11 PM | #12 |
sure is
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
04-20-2014, 11:32 PM | #13 |
2WD Jimmy
I have a BB in my 2wd Jimmy (stock BB location). I am running a TKO 600 with stock BB clutch linkage. I have custom headers, however, I would think a set of standard long tubes would work ok because the collectors would hang down below the frame rail. My custom headers were built with the collectors up high for ground clearance, so the shape had to be engineered to clear the linkage, which is between the frame rails.. Which they do... At a cost$.
04-20-2014, 11:38 PM | #14 |
The first one I did I used the stock SBC linkage. Drove that truck for many years without issue.
04-21-2014, 04:35 PM | #15 |
how did you mount the pivot ball to the block ?
04-21-2014, 05:00 PM | #16 |
Screwed it into the threaded hole on the block.
